Horn not working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gidgy, Sep 5, 2021.
  1. Sep 5, 2021 at 6:48 PM
    Gidgy
    Gidgy [OP] New Member
    2013 TRD Sport
    Recently had steering wheel controls added for Panasonic head unit, a few days later I noticed my horn is no longer working. I suspect that it is related but not certain? Would appreciate any input. Thanks
  2. Sep 5, 2021 at 9:08 PM
    AbeFroman2
    AbeFroman2 Active Member
    2011 TRD Sport
    clock spring
    tcjacado, 12TRDTacoma and Bagman like this.
  3. Sep 5, 2021 at 10:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Or the ground wire was unplugged behind the steering wheel at the very bottom of the Spiral cable ( clock spring).
    12TRDTacoma and TnShooter like this.
  4. Sep 6, 2021 at 2:36 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    That 'blows'.....
    6 gearT444E and Jimmyh like this.
  5. Sep 6, 2021 at 2:43 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it is the clockspring you can always relocate the non functional section of the ribbon to a part that still works. It involves depinning the clockspring connector and relocating it to a different pin and doing the same to it's mating connector. I did it to mine years ago and never had a problem with it after the relocate.
  6. Sep 7, 2021 at 7:38 AM
    TheOnlyPajooned
    TheOnlyPajooned Well-Known Member
    Don
    The 'Couve, WA
    2012 DCLB Sport
    she got big shoes bro
    If you could translate that to English or pictures for simple minds like mine, I'd have a very big smile followed by a determined furrowed brow
  7. Sep 7, 2021 at 8:29 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    It is a multi conductor cables with several spares. Move the broken wire function to an unused good wire.
    12TRDTacoma likes this.
  8. Sep 7, 2021 at 8:42 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Thank you. :thumbsup:
    6 gearT444E[QUOTED] likes this.
  9. Sep 7, 2021 at 12:41 PM
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Just use this. :brianr:
  10. Sep 7, 2021 at 2:22 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Since your horn was working after the SW controls install, I would confirm 12V at the horn connectors before tearing apart the steering wheel. Check for voltage with someone holding down the horn button. If there's 12V, confirm a faulty horn by hooking directly to battery. If there's no 12V, then start by checking the horn fuse and swapping the horn relay for a similar relay in the engine bay fuse block. If still doesn't work, then I would look into the clockspring.
