Horn only works with panic
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sikora8, Apr 22, 2015.
  1. Apr 22, 2015 at 1:36 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    Folks...
    Just purchased a 2012 Tacoma LB TRD with 65k miles...she's a real peach but showed up with a non working horn. Pushed the horn several times with no luck. Actually the horn honked one time. I then pushed the panic button on FOB and it works every time. Fuses seem fine, obviously. Have read something about spiral cable. FYI cruise works fine and no airbag light on. Please advise.
  2. Apr 22, 2015 at 2:05 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    The previous owner must repair the horn to pass the state inspection.
    That's how it works around here.
  3. Apr 22, 2015 at 5:08 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    If you have steering wheel audio controls check to see if they light up. That is another wire that fails in the clock spring (spiral cable). In my case i lost the lights first, then the cruise control then the airbag, all over the course of 18 months and 75,000 km. Replacing the spiral cable fixed all of it for me.
