Horn Out - Its not the fuse, relay, or clock spring - frustrated!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedSoxRobbe, Oct 9, 2020.
  1. Oct 10, 2020 at 4:01 PM
    RedSoxRobbe
    RedSoxRobbe [OP] Active Member
    Nah - that was the first connect before the air bag connections.
    It was out before that.
    But yeah, good place to focus.
    Thanks.
  2. Oct 10, 2020 at 4:04 PM
    RedSoxRobbe
    I'm working on getting it together, today Is hella rainy, or I'd go get some pics of the setup.
    I can also draw up a diagram.
    I was an ET in the Navy and have a fairly extensive electronics background, but have to be honest when I have NOT done much direct electrical work on the truck (with the exception of a BlueSea junction box and a Switchpro.
    Thanks.
  3. Oct 10, 2020 at 6:10 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    LOL. Yes I guess it is.
  4. Oct 10, 2020 at 6:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I commend you for the help you are trying to offer.
    BUT WHO USES A LAND LINE ANYMORE?
    Muddinfun likes this.
  5. Oct 10, 2020 at 6:37 PM
    Waasheem
    Waasheem
    2007 xrunner
    Sounds like an answer I would give
  6. Oct 10, 2020 at 7:30 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    This is a hilarious response in that it's so annoyingly long, yet also resonates with me. I used to work for VZ back in the day and deployed this exact reasoning when I was on strike duty.
  7. Oct 11, 2020 at 6:24 AM
    KactusJack
    KactusJack Well-Known Member
    Collettsville, N.C.
    2014 AC TRD Sport
    Those of us with shit for cell service at home.
  8. Oct 13, 2020 at 6:40 PM
    RedSoxRobbe
    Ok, so let me start by saying thanks to all of you.
    It was a combo of a few things - @Wattapunk (I cleaned the contacts - again), @norsea (actually replaced all the fuses with good ones - again), @caribe (Thanks for the diagram), @EatSleepTacos for the local mental support, and @Jimmyh for the humor!
    SO it works again :thumbsup:
    Clockspring needed to be replaced - I believe this - horn was not working, all checks I did fuse etc initially checked out with a clock spring.
    The panic button triggered the horn, but the steering wheel didn't.
    These (from my limited knowledge but tons of research) checked out against clockspring.
    Let me prepare for the :crapstorm: that'll rain down after I explain...
    909% of this was probably my fault - and I'm good with admitting it - lol.
    After changing the clock spring and all the checks above (all again after you all mentioned them), it did not work - NOR did the panic button this time (key).
    Brain fart check - did I connect the new relay right?
    Went back - double-checked relay plugs - Hell no - not right, idiot factor 10. :frusty:
    Re did em - and guess what.
    So lesson learned - double/triple check - and when mentally frustrated - turn to your brothers for second guesses, diatribes, novels, and humor - while you breathe - reset and get-r-done.
    Thanks again for the help!
    RSR
  9. Oct 13, 2020 at 6:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ohhh yeah!! I forgotten you were local and I gave some wheel bearing advice! Glad to hear it’s all fixed now.
