Horn problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by romeo, Feb 6, 2014.
  1. Feb 6, 2014 at 9:06 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    This morning for no reason my horn just stopped working, I checked the fuses and they were all good. I turned my steering wheel and the horn started working, but when I straightened it back out it stopped working. it works when i turn the steering wheel atleast 1/4 of a turn each way but doesnt when the steering wheel is straight. anyone know what the issue might be?
  2. Feb 6, 2014 at 9:11 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Clock spring in the steering wheel has a broken wire.
  3. Feb 6, 2014 at 9:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Clock spring. Also feeds the airbag, so may be under warranty still, check your book.
    Edit: LOL. Jimmy and I are two for two!
  4. Feb 6, 2014 at 9:22 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    what they said...
    my clockspring has gone out twice...once for the airbag portion and the other for the cruise control. it just went out one day.
    is your truck part of the recall?
  5. Feb 6, 2014 at 9:26 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    That sounds like it might be the issues, not sure if its part of the recall at all. Where can i find out if it is so that i can get it taken care of?
  6. Feb 6, 2014 at 9:28 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    toyota should have sent you a recall letter for it...
    i dont think that any truck 10 and newer was involved in the recall tho, not too sure.
  7. Feb 6, 2014 at 9:32 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    well thats too bad, the letter probably went to my parents house. Any idea how much this will cost to fix?
  8. Feb 6, 2014 at 9:36 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    the part alone is like $300-$350 iirc, and toyota charges like 4 hours to about $400...its not hard to do the swap...just takes time to remove everything and place the new clockspring in correctly
  9. Feb 6, 2014 at 9:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Hey, We are getting pretty good at this!
  10. Feb 6, 2014 at 10:52 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    well this is crappy, so other than my horn is anything else affected by this?
  11. Feb 6, 2014 at 11:12 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Whatever is on your steering wheel will be affected...
    Steering wheel controls, horn, airbag and cruise
  12. Feb 7, 2014 at 2:10 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    cruise control still works
  13. Feb 7, 2014 at 2:12 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    no what is that that all is connected internally in clockspring lol
    certain things may still work but they can go out eventually...or can malfunction like the airbag
  14. Feb 7, 2014 at 6:29 PM
    romeo
    romeo [OP] Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    hope it doesnt happen soon. thanks for all the info and help
  15. Feb 8, 2014 at 5:38 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    The clockspring has I think 12 wires in it. Yours has the wire for the horn ground broken. Over time you will probably have other wires break which will effect other parts...
  16. Feb 14, 2014 at 9:03 PM
    DaVikes
    DaVikes Well-Known Member
    Ross
    Denver
    Colorado Sports Car
    Arb front bumper, warn winch, All Pro rear bumper, OME up front, OME and All Pro Standard in Back, ARB locker, 34 x 10.5 KO2's, 17" Level 8 Trackers, and fancy single piece driveshaft.
    OP, the warranty on "restraint systems" on an '11 is 5yrs or 60,000. My horn just stopped working too, and it seems like the clockspring would be the problem, as the horn will work when the wheel is turned, but it won't when going straight down the road. I just hope the clockspring is part of "restraint systems".
    Now that the horn isn't working, I really miss it. Too many people texting at stoplights.
