Horn quit working... any suggestions?
Discussion in 'Technical Chat' started by eltaco, Jun 9, 2010.
  1. Jun 9, 2010 at 5:35 PM
    eltaco
    eltaco [OP] Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    Let me start this off by saying whatever happened was self-inflicted.
    The other night I was builting a bracket for my new offroad lights to go behind the grille. I took the horns off and removed them from their respective connectors. I had to drive home that night and didn't even think about the fact that the horns must have power at all times, so I didn't put them back on before my return home.
    Fast forward a couple of days and my light bracket and lights are installed. I relocated the horns and went to try them... nothing.
    I just went to check the fuses, but it's absolutely pouring outside. I found a 10A fuse under the hood that was labeled "horn". The fuse looked fine, but I replaced it anyways, which hasn't helped my situation. Is there another fuse that I need to be looking for?
    The connectors only go into the horns one way. I tried swapping horns/connectors, but that didn't help, either.
    Any suggestions would be appreciated!
  2. Jun 9, 2010 at 5:41 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    You made sure to hook them up right. They were plugged in and screwed to something. I know that they ground out the metal bracket, if that isn't properly grounded they don't work.
  3. Jun 9, 2010 at 5:44 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    That
  4. Jun 9, 2010 at 5:47 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Get ready for people to say to use middle finger.
  5. Jun 9, 2010 at 6:26 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Thanks, that is exactly what is going on then.
    I'll fix that issue right away!
  6. Jun 9, 2010 at 6:28 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    Hit it with a hammer if that doesnt work
  7. Jun 9, 2010 at 6:29 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    the easy solution is to keep your window rolled down and just yell HONK out your window as loud as possible
  8. Jun 9, 2010 at 6:32 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    The BFH is always Plan B.
    That's day-1 stuff.
  9. Jun 11, 2010 at 8:43 AM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    I had the ground issue when I moved my horn for grillcraft install. It scared me at first when I needed to use it and had nothing.
  10. Jun 11, 2010 at 8:50 AM
    coppert
    coppert Mall Krawler
    Travis
    916
