Horn relay question
Discussion in 'General Automotive' started by surfsupl, Mar 10, 2011.
  1. Mar 10, 2011 at 1:04 PM
    surfsupl
    surfsupl [OP] Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    My horn in my 2n gen recently has gone out. The fuse is good and I can hear the relay click when I press down on the steering wheel. I put a meter on the end of the clip that clips into the horn and do not get a reading. Is my relay bad? Thanks. Also leading up to this I was blowing my horn fuse hear and their. Any reasons why?
  2. Mar 10, 2011 at 1:17 PM
    surfsupl
    Gregg
    WestCoast
    I do not see a ground wire either. Is it grounded somewhere else on the truck besides next to the horns themselves?
  3. Mar 10, 2011 at 1:23 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Mar 10, 2011 at 1:26 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    looks like the horns ground where they bolt on.are you getting 12v at the horns when you press the steering wheel?
  5. Mar 10, 2011 at 1:29 PM
    surfsupl
    Gregg
    WestCoast
    The thing is that they have worked in the past and when I took it apart today no ground wire connected to the 12mm bolt holding the horns in place?
  6. Mar 10, 2011 at 1:34 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    i think the ground is made through the horn housing,there is just 1 wire going to each horn,which needs 12v when the horn is pressed.if the relay is clicking when you depress the horn,then you are getting the ground from the horn plate needed to activate the relay.if you are not getting 12v to the horns ,check the fuse first,then swap the horn relay and recheck,if you are getting 12v, then the horns are bad.sounds to me like one of them may already be shorted out and been blowing the fuse.
  7. Mar 10, 2011 at 1:37 PM
    surfsupl
    Gregg
    WestCoast
    yes
  8. Mar 10, 2011 at 3:03 PM
    surfsupl
    Gregg
    WestCoast
    Fixed..........I unhooked the batt for 1 hour and then hooked it back up and it works now.
