Horn Relocation Position
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SmilingMark, Nov 11, 2010.
  1. Nov 11, 2010 at 9:45 AM
    SmilingMark
    SmilingMark [OP] Well-Known Member
    Mark
    Ogden, UT
    2010 Access Cab
    Color matched grill w/ grillcraft. BHLM and Morimoto Mini HID's Debadged.
    Not sure if this is the right forum for this so feel free to move as needed. I've noticed alot of folks doing horn relocation and moving it to an area behind the battery where there are already tapped holes that match the mounting bolts for the horns.
    Well, I went looking for these last night in hopes of relocating the horns this weekend along with many other projects. Those holes where everyone is moving them are the mount for the clutch fluid overflow/fill/level indicator. So for those of you with manuals, this may not work. I'm going to see if I can figure out a way to piggy back the horns on the same mount. Will let you know if it works out.
