Horn relocation question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, May 23, 2011.
  1. May 23, 2011 at 7:25 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    Can relocating the horns make them sound different? (more high pitch/cheesy)? I relocated the to the bottom center of the grille area...on that note is there an aftermarket north I could buy that is more manly/louder without having to install inboard air?....pics of my horn relocation to come...I'll also double check the wiring connection when it gets light out. Any help would be great!
  2. May 23, 2011 at 7:34 PM
    Fed Taco
    Fed Taco Well-Known Member
    Cale
    2011 TRD Off Road
    Wheels & Tires, weathertech floor liners, Areo Turbine Exhaust
    I dont think it would change the pitch of the actual horn. But it may sound diferent inside the truck to you because of the placement. (louder or softer)
    When I moved mine it was louder because I moved them to the driver side fender to the pre drilled holes.
  3. May 23, 2011 at 7:37 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    They're louder if you take the little covers off them
  4. May 23, 2011 at 7:41 PM
    TOYOTA 09
    Maine
    Agh I will try this! Suggestions on an after market horn set up (non air)????
  5. May 26, 2011 at 4:14 PM
    jgray
    jgray Well-Known Member
    josh
    boyds,md
    05 Ext.cab "murder was the case"
    Aero turbine sidepipe 3" pipe Murdered out 3"revtek leveling kit 33's
    I moved mine to driver side fender to the pre-drilled holes and now it rarely works
  6. May 26, 2011 at 4:34 PM
    ViperJay
    ViperJay These are the voyages...
    El Paso, TX
    05 Radiant Red DCLB Sport 4x4
    URD CAI, DTLT Headers, Vibrant Ultra Quiet Resonator, Aero 2540i muffler, NST Pulleys, URD MAF Calibrator, Icon 2.5 Coilovers , Bilstein 5100s in rear with All Pro 3" Leaf pack, Total Chaos UCAs, 2 Kicker 12" CVT Subwoofers w/Kicker ZX350.2 Amp, JVC KD-AVX77 stereo, ARE Camper Shell, 1 20" LED bar and 2 7" LED bars in front, 4 KC 6" HID Slimlites mounted on Bajarack roof rack, sliders, Cobra 29 XLR CB Radio, Icom IC-207H UHF/VHF Radio, Bed Lighting, Fog light mod, Projector Retrofit Headlights HID 5000k, HID fog lights 4300k, BHLM, LED taillights and turn signals, Glassworks front fenders, Blue Sea Fuse Box, Mil-Spec Battery Terminals, Odyssey PC2150 battery, Satoshi Grill, All-Pro Front Bumper
    I think its because they use the screw in the back as a ground. When I moved them behind the bumper I used the pre-existing holes and the horn sounded weak and high pitched. So I removed some of the paint around where I mounted it and that seemed to make it sound normal.
  7. May 26, 2011 at 7:44 PM
    TOYOTA 09
    Maine
    ^this is my problem!
  8. May 28, 2011 at 6:31 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    That sounds like a grounding problem to me..... :cool:
  9. May 28, 2011 at 6:54 AM
    jward2331
    jward2331 Well-Known Member
    Fleming Island, Fl
    '08 PreRunner SR5 TRD Sport
    Debadged, tinted windows, upper/lower Grillcraft (horns relocated), Hella 500's with HID Mod (55W 5000) behind grill, shorty antenna, WeatherTech side window deflectors, suspension TSB, Westin Signature Nerf bars, JVC KD A-615 Head Unit with Sirius Direct tuner, Blacked out headlights, DTDL Mod (Switch for on/off), Hard Wired GPS, NOKYA Arctic Hyper Yellow Fog lights, Fog lights on anytime Mod, Michelin LTX M/S2 (P265/65R17), Powder coated OEM wheels. LED ANZO tail lights, Weather Tech FloorLiners.
    I relocated to the Drivers side also and took off the covers. No grounding issues when I did it though, they sound the same to me. Make sure you peel out the temp sensor wire when you reroute the wires so you get the proper temp reading on your upper console.
  10. May 28, 2011 at 7:00 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I picked up a set of horns from the JY for $5 and added them to the existing horns. They are now loud with a distinctive tone. LOL
  11. May 28, 2011 at 8:59 AM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    I'm gonna get the same kind of horns I had on my wrx. Hella horns. 118 db, loud as spit! Have to see if I can mount them behind the grill like I did on the subie.
  12. May 30, 2011 at 12:50 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton/Charleston, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    ^ im glad i saved my Hella Supertones, but i do miss my Subi....
  13. May 30, 2011 at 7:53 AM
    BuckNakedBooda
    BuckNakedBooda There's no place like 127.0.0.1
    Woodbridge, Virginia
    2013 Toyota Tundra Crewmax Limited 4x4
    I just did mine last night when I installed my light bar and a pair of Hella 500s. Now my horn from inside my truck sounds like squeezing the fart out of a mouse. Did you place it here ???
