horn replacement
Discussion in 'Toyota Trucks & SUVs' started by dunwur, Sep 1, 2013.
  1. Sep 1, 2013 at 7:54 PM
    dunwur
    dunwur [OP] Active Member
    toronto Canada
    2011 tacoma sr5 4x4
    I am trying to replace the horn on my 2011 Taco. ( Sounds like the horn on my 4 yr. olds toy car ) . The connection does not fit any of the horns i've seen in the stores . Do I have to cut the wire to my horn and install some kind of adaptor , And if so are there adaptor kits avail ? Thanks .
  2. Sep 1, 2013 at 8:07 PM
    JTacoma
    JTacoma Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Bilstein 5100, 31x10.5 Michelin LTX AT2
    It would be very easy to install another connector. There are many plugs available at auto part stores and shouldn't cost much. I cut mine and split the connection from the button to a switch and installed an additional horn. I also needed to change the plug. That way I could choose between factory and aftermarket. I was also tired of hearing the wimpy factory horn so I installed a set of dual 22 inch long horns. They were too loud most of the time so I needed to be able to switch back to factory.
  3. Sep 1, 2013 at 8:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    ????? Any time I am using the horn, it is with the intention of being heard and it can't be too loud. The only exception might be when giving a couple of toots before backing out of a service bay... which happens practically never.
    I use the phone, or walk up to the door when picking someone up.
  4. Sep 1, 2013 at 8:25 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
