Horn stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pikehk01, Aug 12, 2015.
  1. Aug 12, 2015 at 7:45 AM
    pikehk01
    pikehk01 [OP] Well-Known Member
    Stewart
    Mobile, AL
    '11 SR5 4x4
    Hey guys just needing to pick the brain trust. the horn on my '11 dclb stopped working (not sure how long ago). I've looked and made sure that the wires are still connected to the horn in the front, I have not looked at the fuses yet.
    Thanks in advance for the suggestions and where to look.
  2. Aug 12, 2015 at 8:04 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    thanks ill check out the fuse. when I push the horn nothing happens.
  3. Aug 12, 2015 at 8:08 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    Thanks
  4. Aug 12, 2015 at 8:15 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    is your taco part of the spiral cable assembly recall ? horn goes through spiral cable
    check your vin, may need a new spiral cable assembly
    open up steering wheel and use a multimeter and test horn wire
  5. Aug 12, 2015 at 11:22 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    Fuse is good. ill have to check to make sure the relay is working, then ill look into the spiral cable.
  6. Aug 12, 2015 at 11:44 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I wouldn't recommend opening up the steering wheel unless you really know what you are doing. Don't want an airbag blowing up in your face.
    ArsenalTaco4x4 likes this.
  7. Aug 12, 2015 at 11:50 AM
    ArsenalTaco4x4
    ArsenalTaco4x4 Well-Known Member
    Texas
    2011 TRD OR DCSB
    I do not believe the E0M(spiral cable recall) does not go to 2011, just 2009 on the taco. Check the relay before you try to get into the wheel, air bags hurt.
  8. Aug 12, 2015 at 11:50 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    yes I took out the old and replaced with a brand new one.
  9. Aug 12, 2015 at 12:44 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    just put your VIN into this site
    http://www.toyota.com/recall
    and that answers all the questions about it
    and I double-dog-dare-you to show me anyone who removed the
    air bag from a toyota steering column (who wasn't a complete and total knob) and had an airbag go off.
    step 1 disconnect battery
    step 2 open up steering wheel
    step 3 locate air bag connections and disconnect
    step 4 locate horn wire
    step 5 reconnect battery
    step 6 test connectivity with multimeter
  10. Aug 13, 2015 at 6:30 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    I looked up the recall and there is nothing on there for the horn. so I am hoping that it the relay
  11. Sep 14, 2015 at 3:05 PM
    ThirdCoast
    ThirdCoast Well-Known Member
    Houston
    2011 DC TRD TX
    Subbed, mine is working intermittently. Any update on yours?
  12. Sep 14, 2015 at 3:54 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    My horn didn't work when I bought the truck. Dealer determined the ground wire in the steering column itself was never/not connected. Therefore the horn switch never functioned.
  13. Sep 14, 2015 at 4:07 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Carry an air horn?
  14. Sep 15, 2015 at 11:38 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    I pulled the horn relay, but have not gotten a new one yet. Once I do and test it I will post here.
  15. Sep 17, 2015 at 12:31 PM
    ThirdCoast
    Houston
    2011 DC TRD TX
    I'm at the dealer, found out it was the spiral cable, but I have the extended warranty, so it's covered.
  16. Oct 10, 2015 at 7:40 AM
    Time907356
    Time907356 Member
    tim
    2011 Toyota Tacoma 4x4 Acc. cab, SR5
    Hey, just joined the forum; same problem on a 2011 SR5. I swapped relays, swapped fuses (both checked out) shoved a jumper across the high voltage relay terminals, and it honks. What's this spiral cable thingee? How much will a repair be??
    (edit-) ...Ok so the spiral cable thing is what I'd call a slip ring, but whatever...I've noticed a couple of other things with the steering wheel. It doesn't lock when the key is removed, and the wheel is swung to the extreme (related??) and I suspect the air bag is not powered either. Is it possible that these three are related?
    The weird thing is that the radio controls still work, which also go through the spiral cable.
  17. Oct 10, 2015 at 7:57 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  18. Oct 10, 2015 at 8:40 AM
    Time907356
    Time907356 Member
    tim
    Thanks! I followed YT and pulled the part out in about 15 min. I don't have a spare ($13 ebay) but will get one. The question: will it fix the horn, or are there other points to check?...
    I'm going through the wiring diagram to find the backside lead. If I ground it, the horn should go off. If it doesn't, it's not the spiral cable.
  19. Oct 19, 2015 at 10:54 AM
    pikehk01
    Stewart
    Mobile, AL
    '11 SR5 4x4
    Ok so I get around to putting in a new relay and that did not fix the horn. I have looked at the recall list for my truck and it does not show that the spiral cable is available for replacement.
  20. Oct 19, 2015 at 1:05 PM
    Time907356
    Time907356 Member
    tim
