Horn Upgrade
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chettytac, Sep 23, 2022.
  1. Sep 23, 2022 at 2:13 PM
    chettytac
    chettytac [OP] Well-Known Member
    chet
    2009 Toyota Tacoma Access Cab v6 4wd
    Hello Peeps,
    I notice my 2016 SR5 Tacoma, has only one horn and the pitch is low. My 2016 trd sport has two and the pitch is high. Can I upgrade the sr5 horn.
  2. Sep 23, 2022 at 2:15 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I dunno anything about the Sport horn, but this is the horn I've been thinking about installing on my truck:
    chettytac[QUOTED][OP] and TS4x4 like this.
  3. Sep 23, 2022 at 2:17 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    TGIF. Sign up for PornHub Premium.
    whatstcp, Benny blanco and TS4x4 like this.
  4. Sep 23, 2022 at 2:29 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
  5. Sep 23, 2022 at 3:52 PM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
  6. Sep 23, 2022 at 3:55 PM
    Bishop84
    Bishop84 Well-Known Member
    3rd gen taco has the loudest factory horn I’ve heard in ages. Never seen someone complain about them. Even if one is only performing 50%
  7. Sep 23, 2022 at 3:55 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    RustyGreen likes this.
  8. Sep 23, 2022 at 3:56 PM
    Chaosh1
    2021 Tacoma TRD Pro
    yes sir .. but 123 DB...
  9. Sep 23, 2022 at 3:57 PM
    Key-Rei
    Key
    Florida
    At 3ft.
  10. Sep 23, 2022 at 6:13 PM
    chettytac
    chet
    Thanks
  11. Sep 23, 2022 at 6:47 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
  12. Sep 23, 2022 at 6:59 PM
    The
    The Well-Known Member
    '17 TRD 4x4
    Shit I found on CL or EBAY that I could screw on.
    I did two of the Marco brand horns. Definitely louder, sounds like a yacht.
    Just make sure if you're using higher amp draw horns, run a separate power line and relay. iirc, the stock horn is relayed through the ecu or something like that. If you blow that circuit, you won't have a horn.
    https://www.amazon.com/Marco-112030...=1663984818&sprefix=horn+marco,aps,120&sr=8-1
    https://www.amazon.com/MARCO-112310...0&sr=1-2-27ba7c8b-4ccd-4740-99bc-12e677c1bbb6
  13. Sep 23, 2022 at 7:02 PM
    5efvz
    5efvz Well-Known Member
    i hear hella supertones and sharptones are good
  14. Sep 23, 2022 at 7:03 PM
    trdo-r
    trdo-r Well-Known Member
    17 TRD Off-Road
    The pro comes with a desert air horn. Or something like that, idk. Was discontinued.
  15. Sep 23, 2022 at 7:03 PM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  16. Sep 23, 2022 at 7:21 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Hella sharp tones in my truck
