horn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Linus Majorus, May 5, 2023.
  1. May 5, 2023 at 9:32 PM
    Linus Majorus
    Linus Majorus [OP] New Member
    2013 white Tacoma TRD 4x4, 4 door
    Black Oak 40 W. led back up light; 200 lb. tread plate in bed; Chrome bull bar; K&N air and smog pump air filters.
    My horn doesn't work in the straight ahead position, but honks if I turn the steering wheel to the right or left 15 degrees or more. My cruise control works and all the steering wheel function buttons work. The horn fuse is good and there is power to the horn relay. If I jumper 3 & 5 pins on the horn relay the horn blows. I have removed the steering wheel horn cover and the brown wire is hooked up to the spade connector on the air bag assembly. I did NOT remove the clock spring because the forum states " if the cruise control and steering wheel function buttons work then the problem is NOT the clock spring". I need some suggestions, please! PS.: I have a 2013 Toyota Tacoma TRD, 4WD, 4 door P/U. Thanks
  2. May 5, 2023 at 10:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Clockspring, there's not really anything else it can be. The other circuits just haven't failed yet.
    Jimmyh and 6 gearT444E like this.
