Horn
Discussion in '2nd Gen. Tacomas (2005-2015)' started by robalan57, Jan 17, 2025.
  1. Jan 17, 2025 at 3:29 PM
    robalan57
    robalan57 [OP] New Member
    2006 and 2008 extended cab and double cab 4WD
    My Tacoma 2006 horn only works when the steering wheel is turned 90 degree or more. How can I fix it?
  2. Jan 17, 2025 at 3:32 PM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
  3. Jan 17, 2025 at 5:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Classic bad clockspring (Spiral Cable).
    Pretty easy fix, part is somewhat expensive though unless you go with a questionable china knockoff.
  4. Jan 17, 2025 at 7:17 PM
    AnotherDude
    AnotherDude Well-Known Member
  5. Jan 17, 2025 at 8:36 PM
    DailyTacoMD
    DailyTacoMD Well-Known Member
    Jeremiah
    2006 2.7L AC 4x4 5spd
  6. Jan 18, 2025 at 6:41 AM
    AnotherDude
    You're right. Consider grabbing a cheap one and checking. If you want the OEM quality you can always try and repair your original. I'm not sure what's wrong exactly but likely a worn out electric connection. Dab some isopropyl and enjoy.
  7. Jan 18, 2025 at 8:47 AM
    vtdog
    vtdog Well-Known Member
    NH
    I had to replace the clock spring in my '11 a while back. I found out that the clock springs are identified via your VIN which shows the equipment that is connected to the clock spring. I chose to use OEM part from local dealer as my experience with after-market electrical parts has not been good. I had to replace a blower resistor that I bought on Ebay which was allegedly OEM in 10 weeks. The clock spring is not a difficult repair (there is a really good YouTube video), but (and it is a very important but) you have to work around the airbag. I simply did not want to tempt fate more than once, so I went with OEM. The cost was about $ 300 which was reduced from the rack rate as I showed the parts guy a listing for an on-line Toyota dealer and he matched the lower price. The whole repair took me about 90 minutes, but I was being very careful and slow. I suspect that if you really knew what you were doing you could do it in under an hour.
