Horrible alignment even with tc uppers ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, Feb 25, 2017.
  1. Feb 26, 2017 at 3:37 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    The shop told me to install my new tires and bring it back to fix the camber lol...gonna bring it back for sure...stand there and watch him do it properly
  2. Feb 26, 2017 at 3:38 PM
    anthony250f
    Anthony
    San Diego, CA
    I thought that if you move the rear cam to get caster and THEN move the front it would cancel eachother out ?
  3. Feb 26, 2017 at 3:38 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Why the hell wouldn't they just fix the camber right then? Changing tires doesn't change the alignment.
  4. Feb 26, 2017 at 3:41 PM
    Justinlhc
    It does, but not at a 1:1 ratio. Hard to explain, but you will sacrifice a bit one way or another. The positions of each point on the LCA dictates what gets changed the most. The rear cam adjusts caster more than camber because of its position while the front cam adjusts camber more than caster.
  5. Feb 26, 2017 at 3:43 PM
    anthony250f
    Anthony
    San Diego, CA
    Exactly!!!!! Cause now I can't even turn with my new tires cause the caster is so bad...drives like shit too.
    I was about to buy new spindles thinking these were bent
  6. Feb 26, 2017 at 3:45 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Both of them adjust caster and camber at the same time. There isn't one which specifically adjust caster and the other camber.
    Check your spindles, they may be bent. Hopefully that's all that it is. Otherwise, frame.
  7. Feb 26, 2017 at 3:53 PM
    Justinlhc
    This is true, BUT one does adjust MORE than the other.
    Regardless of anything, the current position of the cams indicate there is room to align it properly. Unless shit is twisted up like a pretzel you'll be ok.
    12TRDTacoma[QUOTED] likes this.
  8. Feb 26, 2017 at 3:55 PM
    anthony250f
    Anthony
    San Diego, CA
    The spindles look fine...I know the truck did have more caster before I replaced the lca because the tires didn't rub and it drove great...it also didn't have negative camber
  9. Feb 26, 2017 at 6:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You might want to make a very solid look at your suspension or have a third party inspect it. You may still have something bent.
  10. Feb 26, 2017 at 6:20 PM
    anthony250f
    Anthony
    San Diego, CA
    It's possible I guess...I feel like if the frame was bent then my front bumper would not have lined up properly. I replaced everything besides the spindle
  11. Feb 26, 2017 at 9:25 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
  12. Feb 26, 2017 at 9:49 PM
    anthony250f
    Anthony
    San Diego, CA
  13. Mar 23, 2017 at 5:13 PM
    anthony250f
    Anthony
    San Diego, CA
    UPDATE: went to get the alignment today again and something is def fucked on the passenger side...put the rear cam all the way out....and the front cam all the way in and it was -2 degrees caster
  14. Mar 23, 2017 at 6:24 PM
    Justinlhc
    Did you install the arms on the wrong sides? :homer:
  15. Mar 23, 2017 at 6:25 PM
    #35
    anthony250f
    Anthony
    San Diego, CA
    Haha no!!
  16. Mar 23, 2017 at 6:30 PM
    #36
    Justinlhc
    That's the only thing that would explain it.
  17. Mar 23, 2017 at 6:38 PM
    #37
    anthony250f
    Anthony
    San Diego, CA
    I think the spindle must be bent
  18. Mar 23, 2017 at 7:47 PM
    #38
    Justinlhc
    EXTREMELY bent to cause this. You're talking a ~4° bend o_O
    tetten likes this.
  19. Mar 23, 2017 at 7:51 PM
    #39
    tetten
    Andy
    Socal
    Yeah, at minimum.
    Did you go to a different shop instead of the same one?
    Did you reposition the cams and then go to a shop?
  20. Mar 23, 2017 at 8:40 PM
    #40
    anthony250f
    Anthony
    San Diego, CA
    I was physically in the shop playing with the cams and watching the alignment machine...I can't beleieve it. I ended up with 1.1 caster...but I had to turn the cams opposite to get there....as in my tires rub worse lol
