HORRIBLE ENGINE PROBLEM
Discussion in '1st Gen. Tacomas (1995-2004)' started by Babbar Khalsa, Apr 16, 2011.
  1. Apr 16, 2011 at 4:27 AM
    Babbar Khalsa
    Babbar Khalsa [OP] Member
    Manjot
    Cooper City FL
    03 PreRunner SR5 2.7l
    Stock
    My tacoma 2.7 l was low on gas the other day, the tank was completely empty and without knowing the tank was completely empty i thought it had a little left to drive to the gas station. I hit the ignition and no start =/(I think all that junk from inside my gas tank went in the fuel line) . the tacoma now has a low idling problem. And sometimes it even stalls.
    Any help is very appreciated :)
  2. Apr 16, 2011 at 4:30 AM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Fuel filter might of suck dirt in, not sure though
  3. Apr 16, 2011 at 5:32 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Try a really good concentrated fuel injector cleaner. It may clean it up a bit.
  4. Apr 16, 2011 at 5:43 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    after you run some cleaner thru it, take it out for a blast for an hour or so. run it hard and then see if it is better.
  5. Apr 19, 2011 at 11:12 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    If that happened to me (and it has) I would go with a new filter. You probably sucked up the dirt marbles in the tank and plugged off your filter.
    I would also put some Lucas inj cleaner thru it afterwards to flush out the really fine stuff that might have made it thru the filter and into your upper system.
