horrible gas milage while towing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kubota man, Oct 18, 2009.
  1. Oct 18, 2009 at 10:36 AM
    kubota man
    kubota man [OP] Well-Known Member
    hazard ky
    08 trd off road dc 4x4
    My son is in a high school band and as a band daddy i volunteed to use my kubota rtv 900 a utv type fourwheeler that weights in at 2300 lb. with the cab to pull props on and off the field.now my 2008 tacoma dcab 4x4 trd off road pulls it fine but im only getting 10 mpg so it seems to me that a lot to give up from 19 mpg when not pulling any thing. we live in a hilly area. but we still have 3 more weekend of compatition left. these truck mpg falls on there face while pulling anything makes me start thinking should i have gotten a tundra. on a brighter side only 3 more weekends but i still love my truck im disapointed with mpg. should have looked at only 28000
  2. Oct 18, 2009 at 10:38 AM
    fghtngsquirrel
    fghtngsquirrel Ka-freakin'-BOOM!
    Jacksonville, FL
    '08 4x2 Rad Red *SOLD*
    We pulled a car and car trailer from Iowa to Jacksonville, FL a few months back and my MPG only dropped 2-3... we ran 93 octane the whole way back :notsure:
  3. Oct 18, 2009 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Towing anything is gonna affect the mpg. Add hills and it gets worse. Im sure the Tundra, being as the reports I have gotten put it at 12 mpg unlaiden, would get worse mpg than the Tacoma.
  4. Oct 18, 2009 at 10:44 AM
    kubota man
    hazard ky
    may be i better get it checked out
  5. Oct 18, 2009 at 5:07 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    Everything will get worse mileage towing. My Tacoma normally gets 20-21 MPG on the highway and this year towing my boat it got 17-18 MPG. By comparison, my old F-150 was lucky to get 17 MPG on the higway unloaded and towing the exact same boat, I would get 12-13 MPG. So when you look at it that way, my Tacoma actually gets similar mileage towing my boat as compared to what my old F-150 did unloaded . . .
    I guess the primary benefit to going with the Tundra would be the capability to tow much heavier loads more effectively than the Tacoma. Overall though, I really doubt that you'd see any cost savings when talking about a 2,300 lb trailer. Actually, I think you'd see overall increased costs just because of the additional fuel useage you'd use with the Tundra while not towing.
    The fact that you are seeing a drop from 19 to 10 leads me to believe that your trailer has allot of wind resistance, the terrain is really challenging, you have lots of heavy throttle application, etc. These are things that will severely impact the MPG for any tow vehicle, Tundra included. Unless you are running into a situation where the Tacoma is running into capability issues, I'm not sure it makes much sense (from a pure MPG argument) to switch over to a full size.
  6. Oct 18, 2009 at 5:35 PM
    tegdog
    tegdog Taco Lover
    Indiana
    09 Tacoma Dbl TRD Sport
    ventvisors,seatcovers, bug shield,TRD CAI,TRD CAT BACK,blacked out emblems,bed extender, TSB leaf pack,Pro Dry filter, Grill craft upper, lower, & triangles, Hella 500 Black magics
    I had a 06 Tundra with 4.7, it only got about 14mpg around town unoaded and pulling my camper probably around 10mpg ot less. I get 14mpg with the Taco pulling the same trailer, & 16-18 around town unlaoded. My Tundra wasnt rated to pull much more weight either it just it did more easily up hills and from standing starts, it was definately not more fuel efficient.
  7. Oct 18, 2009 at 6:16 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I have seen 10mpg in a buddies V-6 TRD off road towing a 18 ft trailer with only two dirt bikes in it at highway speeds! :eek:
  8. Oct 18, 2009 at 6:55 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I may have even got worse then 10MPG pulling my 4500Lb 24ft Jayco trailer from Ontario to Nova Scotia this summer, I was not happy.:mad:
  9. Oct 18, 2009 at 7:18 PM
    NMG
    Ottawa
    That's a fair sized trailer with a large amount of surface area and pulling it through the air at highway speeds is just simply going to require allot of work on the part of your truck. You just can't get over the physics of it. Getting around 10 MPG towing that load, especially with a V6, isn't really THAT bad IMHO. I'll bet you did no worse than most 1/2 ton V8's would do with a similar load . . .
  10. Oct 18, 2009 at 7:20 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    you might want to consider a TRD supercharger. It'll give you the boost you need and save you a few mpg. Less of a struggle for your na 4.0 engine
  11. Oct 18, 2009 at 9:49 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    "10mph"???
  12. Oct 19, 2009 at 12:32 AM
    meafordmike
    Maybe I can sell this to my wife, because it is "her Trailer" HAHA.
  13. Oct 19, 2009 at 5:59 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    Personally, I would not buy a Tacoma for towing anything with "weight" on a daily or weekly basis. Small truck, tow small things. Big truck, tow big things. I tow a 6000 lb 25 ft travel trailer with a diesel rated at 10,000 lbs, and feel I am getting close with this "work ratio" load wise. Can not imagine a 24 ft 4500 lb load with a 6500 lb rated truck for very long. Not that it can not handle it, your just working it hard, hence the bad gas mileage stated above. :cool:
  14. Oct 19, 2009 at 8:55 AM
    WV_Tacoma
    WV_Tacoma Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    05 V6 Prerunner, tow 5k travel trailer and I get 10-12. Depends on my hills.....Just how it is. Not bad for gas pusher V6....
  15. Oct 19, 2009 at 9:00 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I got about 90 miles on one tank pulling a 19ft toyhauler(5500lbs) against 30-40mph winds. I was p/o'd.
  16. Oct 19, 2009 at 10:08 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    yes when we tow our enclosed trailer in the winter time snowmobiling our mileage is around the 10-12 range. Winter blend gas, mtns, etc. A big ol' non-aerodynamic box behind us. :eek:
    We use to get around a consistant 14 in the 4.7 V8 tundra (1GEN). I was a little surprised but it is what it is I guess. Doesn't stop us from going on our trips. :D
  17. Oct 19, 2009 at 1:38 PM
    valleythunder
    valleythunder Well-Known Member
    Rob
    Dahlgren, VA
    08 DC/LB
    I have a 24' SeaArk C/C Jon boat, tandem axle galvanized trailer. With my DC/LB 4x4 I get 11.5 mpg (avg.):). The f-150 2wd 4.6l v-8 I traded for the Taco, got 10 mpg...... So much for the v-8 theory.......:eek:
  18. Oct 19, 2009 at 11:15 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I'm sure any truck it will lower the MPG when towing. I get an avg of 18 when I'm not towing, but I speed (Atlanta autobahn). When I tow my bass boat I get 12-14mpg. Some hills in my area.
  19. Oct 20, 2009 at 5:50 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    The Tacoma actually gets great gas mileage when towing if you start comparing to the guys that run the bigger gas trucks. My 26' travel trailer weighs in just about 5000# and I get between 9-12mpg depending on where I'm going. Read RV.NET forums and see what some of these guys are getting... 5-7 in a lot of cases. For the "little" bit that I tow (4000 miles out of 93000 on the truck) I'm more than happy to get 20mpg when not towing and 10 when towing. Sure has saved me $$$ from a full size truck that gets "bad" mileage all round towing or not.
  20. Oct 20, 2009 at 6:06 PM
    leg killa
    leg killa Well-Known Member
    AMERICA
    06 SBDB SR5 4x4
    TRD Hood/ Color matched grill/ De badged/ BHLM/ Viper remote start/ Pioneer AVIC Z-130BT/ BFG MT KM2/ MT Classic II/ OME Lift/ LR UCAs/ Pop and Lock
    so im stationed on fort bragg, NC and i have a good chance on being stationed in washington state....i want to tow my wifes chevy colbat which weighs about 2800 lbs..i will need to get a tow package, tranny cooler..i dont have the tsb thing done..if i do this i plan on renting a dolly or something from u haul
    could i do this? would it suck really bad? if i do get sent to washington state it will be next summer which leaves me alot of time to upgrade my truck
    ive been thinking about this for awhile so any help will be nice
