horrible gas milage
Discussion in '1st Gen. Tacomas (1995-2004)' started by wheeelin&blazin, Jan 18, 2010.
  1. Jan 18, 2010 at 10:41 PM
    wheeelin&blazin
    wheeelin&blazin [OP] New Member
    Jt
    Big Bear CA
    wheelin
    none
    i just got a full tune up done on my taco and my mpg has gone horribly bad. is there a common proublem that happens with tacos any advise on were i might start dont have enough cash to go to a shop, a little bit of mechanical abillity
  2. Jan 18, 2010 at 10:42 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Bad O2 sensor?
  3. Jan 18, 2010 at 10:43 PM
    TRDsport2010
    TRDsport2010 Grease Monkey
    Corey
    Houston, Texas
    2010 Silver TRD Sport
    What all did they do when they did the tune up? How many miles on the truck?
  4. Jan 18, 2010 at 10:49 PM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    Can a bad o2 hurt your gas millage
  5. Jan 18, 2010 at 10:54 PM
    TRDsport2010
    Corey
    Houston, Texas
    yes but It wont normally hurt you that much. and "normally" if it is THAT bad it will set a check engine light
  6. Jan 19, 2010 at 6:40 AM
    ywen
    ywen Well-Known Member
    maybe the way you're calculating it?
  7. Jan 19, 2010 at 6:45 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Are you heavier on the gas pedal now that you got the tune up? Driving style affects mileage more than anything else.
  8. Jan 19, 2010 at 7:29 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah, I would first check your o2 sensors. Mine were bad and I got shitty mileage. And after the new ones it jump up about 3-4mpgs.
    But driving style does effect it also, If im hard on the pedal or drive more agressive my mpg's will go way down on a tank.
  9. Jan 19, 2010 at 4:26 PM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Well I read somewhere (when gas was $4 a gallon) that a bad o2 sensor can reduce your mpg by 40%
  10. Feb 1, 2010 at 10:27 AM
    NCSU-Cohiba
    NCSU-Cohiba Member
    Bryce
    Raleigh, NC
    00' Prerunner Extended Cab V6
    3 in. body lift, flowmaster exhaust.
    my 00' 3.4 gets 13 mpg, uphill, downhill, with the wind, against the wind, and in neutral. I don't know what to do with it.
  11. Feb 1, 2010 at 10:42 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    Hmmm did they change the plugs? Maybe the wrong ones were put in or not gapped correctly.
  12. Feb 1, 2010 at 1:55 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I had the wrong oil put in another car of mine and it change the mileage. I changed the O2 sensors on my 2000 V6 4x4 and started getting 19-20 out of it...22 on the highway. I'd like to change them on my current truck but they are EXPENSIVE
  13. Feb 1, 2010 at 5:26 PM
    2004Taco
    2004Taco Well-Known Member
    Long Beach,CA
    04 PreRunner SR5 Trd
    Magnaflow and Deckplate Mod Billet grille
    Haynes repair manuals help me a lot. you can get this at your local auto store. I got mine from Auto Zone. try getting one, it should narrow down the problem.
  14. Dec 18, 2011 at 6:58 AM
    buckey48
    buckey48 Member
    Hayward, CA
    SC Doublecab 4x4
    TRD super charger
    I have the same problem. Mine used to get 16+ in combinded driving. 20+
    on the freeway.
    Took a 1400 mile road trip over Thanksgiving, just under 19mpg, but now that I am back I am getting under 14.
    Plugs were changed at dealer, o2 sesonsors both have been changed.
    Thou when the 02 sensors were change he checked obdII and showed something was running rich, this was with a cold engine.
    Passed CA smog with no problem
    Could not get to all injectors to test because the Supercharger is in the way.
    Only other thing change tires, same size but now running Bridgestone revo II's. I did read a lot of people said they had a mpg drop with this tire, but over 2mpg?
    My neighbor has a full size v8 Chevy truck and gets 20mpg
  15. Dec 18, 2011 at 7:28 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Whats horrible?
  16. Dec 18, 2011 at 11:12 AM
    spidy3
    spidy3 Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    OP... what did they do for the "tune-up"???
    I changed all my fluids/plugs/air and fuel filter a little after I got my truck and didnt notice any mpg change. The previous owner did all the services regularly so I didnt expect much.
    I went from 265/65/17 grand trek tires 20-22mpg to 265/70/17 goodyear wrangler 18-19mpg to my winter tires firestone winterforce 265/75/16 16-17mpg all highway #s so tires (size/brand/tread) do make a difference.
  17. Dec 18, 2011 at 1:12 PM
    twfsa
    Tom
    Omaha Ne
    04 TRD 4X4
    Whats the MPG you are getting? what are you driving V6 4 cyl auto/stick?
  18. Dec 19, 2011 at 2:13 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    My MPG has gone down a little too lately.:confused: I'm thinking it could be due to the winter gas they have switched to. During the winter months, companies use different types of additives then they do in the summer time. At least here in Cali anyways. Not sure in other states.
  19. Dec 19, 2011 at 3:57 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    I always get worse mileage in winter and especially in colder weather. Our trucks are notorious for being whiny about cold temperatures. I can get 23.5 on an all highway tank in summer, and in winter I get 18. :frusty: Blows.
  20. Mar 12, 2012 at 4:08 PM
    buckey48
    buckey48 Member
    Hayward, CA
    SC Doublecab 4x4
    TRD super charger
    13 or so maybe 15 with some hiway driving.
    used to be 15+ and 18+ all hiway 19 now. 21-22 before.
    At $4.50+ per gal it sucks.
