Horrible gas mileage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PhilipRoth, Nov 13, 2012.
  1. Nov 13, 2012 at 10:56 AM
    PhilipRoth
    PhilipRoth [OP] Well-Known Member
    Az
    06 Tacoma
    King shocks!
    When I purchased my truck 4 years ago I was getting 20 mpg's on the highway and 17 in town. I currently now get 15 highway and 13 town. It's an 06 with 106,xxx miles. My driving habits are the exact same and for the 15mpgs on the highway was straight from Phoenix to Blythe ca all Highway driving and didn't go above 2500 rpm. Anyone have any suggestions on what could possibly be wrong?
  2. Nov 13, 2012 at 10:58 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    When's the last time you changed Spark plugs? Air filter? Cleaned/replaced MAF sensor?
  3. Nov 13, 2012 at 11:00 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Plugs and such, I noticed my mileage nosing over a bit as I approached my 30K interval plug replacement. Once replaced it went right back where it was before.
  4. Nov 13, 2012 at 11:02 AM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    Honestly haven't changed the spark plugs in 50k miles. Ill get right on that, and I have a Volant CAI that I clean regularly and I have the urd MAF sensor
  5. Nov 13, 2012 at 11:02 AM
    PhilipRoth
    Az
    06 Tacoma
    King shocks!
    How would I go abou cleaning the MAF?
  6. Nov 13, 2012 at 11:31 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
    Also check your tire pressure... mine had dropped 5psi w/out the warning light turning on. Dunno what the tolerance on the tpms is, but I always check once per month.
  7. Nov 13, 2012 at 11:44 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '16 Inferno DC LB 4x4
    None yet, starting over!! OME lift w/ Dakars & 885's Remote Start w/ window control
    Issues with low MPG's in the past were typically solved with new plugs and/or air filter.
    New solution also included non-ethanol gas www.pure-gas.org
    Haven't cleaned my MAF in the 2+ years I've had the truck, about 45k miles, so I should probably look there as well
  8. Nov 13, 2012 at 11:46 AM
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    As far as I know, you can remove the MAF, clean with electrical or carb cleaner, and let air dry. Dont touch or try to wipe dry...Repeat as necessary. I would recommend looking into it before you ruin something tho...
  9. Nov 13, 2012 at 11:58 AM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    Cleaning the sensor is extremely easy. CRC makes a "Mass Air Flow" cleaner for about $10.00. Just pull the electrical plug to the sensor, remove the two screws and lift the sensor up and out (pay attention to direction it came out for re-installation). Then with the straw attachment on the can direct the straw up into the tube holding the very small (looks like a little resistor) sensor, DO NOT TOUCH THE SENSOR! Give the sensor 10 or so short blasts of the cleaner (as per can directions) and then allow it to dry for about 5-10 minutes (dries very fast and does not leave any residue). Re-install and the ECU should shortly react to the new readings and adjust your air fuel mixture accordingly. I clean mine every six months.
    NOTE: Read can directions before starting.
