Horrible gas mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by socaloctacoma, Dec 14, 2019.
  1. Anything
    3 vote(s)
    100.0%
  2. Anything
    3 vote(s)
    100.0%
Multiple votes are allowed.
  1. Dec 14, 2019 at 9:11 PM
    socaloctacoma
    socaloctacoma [OP] Active Member
    Tanner
    2008 TACOMA
    Hello, I have a
    2008 Tacoma long bed V6 4.0L with 33inch tires (189,000) and I’ve always been able to get 15mpg city and around 17 hwy(Even with the 33’s!)
    Ever since I installed this camper shell(are series) I am now getting 10mpg and 12 hwy.
    I have tried the following:
    Tire pressure all around 29psi
    Clean air filter
    Fresh spark plugs
    Just cleaned MAF sensor (no difference)
    I am not sure what else to do and was wondering if anyone would be so kind do suggest some tips.
    Adding a camper shell shouldn’t decrease it that bad (or maybe I’m wrong)
    On a full tank(21.1) gallons, I can go only 230 miles. And that’s mostly highway driving and keeping the rpms lowwwww
    It’s getting expensive with $4/gallon gas prices
  2. Dec 14, 2019 at 9:14 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Shell disrupts airflow and reduces MPG.
    29 psi is low as shit.
    You added 150+ lbs of weight to your vehicle and that doesn’t help either.
    33s aren’t for mileage.
    12TRDTacoma, Kolter45 and Sreppep like this.
  3. Dec 14, 2019 at 9:15 PM
    Sreppep
    Sreppep Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    Have you always ran 29psi? Sounds a little low to me, I run 34psi on my 265/75r16. I noticed no difference in mpg when installing my high top shell... or atleast the shell didn’t decrease enough to affect me like that. Maybe 1 mpg less at most.
    TacomaUSA likes this.
  4. Dec 14, 2019 at 10:06 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    My canopy has never effected my mileage either. I agree that the 29 psi is low, especially in the winter time. Could just be the change to winter gas in your area. I’d reset your computer, let it learn for a tank of gas, and then re check your mileage manually.
  5. Dec 14, 2019 at 10:32 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    I'm getting 13.9 mpg freeway with 305/70R16s, front Bilstein 5100s, and a leer camper shell. 5 mpg less than stock. It's pretty terrible but I just stopped paying attention to how many miles per tank I get and know that I'll just need to fill up twice a week now. $400 a month roughly unless I get stuck at work...
  6. Dec 15, 2019 at 12:48 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    15-17 then added a shell and 10-12.
    Tires and pressure same before and after, even while maybe low, did not change.
    What else did you do around the same time as this does not add up.
    Shell as others said maybe 1-2 decrease at most.
    189k miles so how are all the wheel bearings and rear diff as mine all went at 100k and a major drag/mileage reducer.
  7. Dec 15, 2019 at 12:57 AM
    Mohedano1
    Mohedano1 Well-Known Member
    Ogden, Utah!!
    '15 4wd DCSB TRD Offroad
    Total Chaos uca, King 700lb extended coilovers, King Tundra rear shock w/resi, BruteForceFab Hybrid front bumper, BruteForceFab rear HC bumper, BAMF skidz. 315/75/16 cepek extreme country, 4.88 gears, front arb locker. Rci sliders and diff skid
    Is your odometer correctly calibrated? Changing tire size throws it all off. Types of tires, width, gearing,weight,etc...
    TacomaUSA and RoNeil like this.
  8. Dec 15, 2019 at 1:49 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Camper shells usually aren't much trouble to install & remove. Would it be feasible to remove it & run a tank of gas, if mpg. goes back up, that's the problem, if not, look for something else.
    melikeymy beer likes this.
  9. Dec 15, 2019 at 8:57 PM
    socaloctacoma
    Tanner
    2008 TACOMA
    @muddog321
    I replaced the front wheel bearings about 4 months ago. (Didn’t buy the ones you press in I got the whole hub assembly)
    And I changed my CSB & U joints as well as a driveshaft balance.
    However for the 100,000 miles I’ve owned the truck I haven’t touched the rear diff fluid yet.
  10. Dec 15, 2019 at 9:05 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I'd do both diffs if you're 4x4, and your transmission fluid if you're a 6 speed.
    Not sure what the maintenance interval is supposed to be for the auto transmissions, but it's recommended to replace the front and rear differential fluids around 65k miles if I remember correctly. That's when I did mine. 100k miles seems like wayyyy too long to go without changing diff fluids.
  11. Dec 15, 2019 at 9:16 PM
    socaloctacoma
    Tanner
    2008 TACOMA
    @Ccrames2018
    Thank you for the tip
    It’s 2wd, I’m gonna add it to my to-do list for this week
    For the trans, fluid was changed about 20,000 miles ago however I didn’t use “WS” fluid, I used Valvoline ATF but I really need to change it again so I can get the right fluid
    Ccrames2018 likes this.
  12. Dec 15, 2019 at 9:21 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Yeah it's fairly cheap to do the diff fluid, and just follow the owner's manual for the tranny fluid. Good luck!
  13. Dec 16, 2019 at 5:19 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My cap adds 180 lbs to curb weight, but it also makes the truck more aerodynamic. If anything my fuel mileage improved with the cap. I ran just under 40 PSI with P series tires, closer to 35 PSI with LT's. I get 20 mpg hwy, 16ish for normal every day driving with 31.5" Lt265/75/16 tires on my 07 4X4.
    29 PSI is OK for off road driving, but way low for every day use.
  14. Dec 16, 2019 at 5:39 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Are you taking into account that your odometer is no longer accurate with 33s ... so the M in your mpg calculation is going to be off.
  15. Dec 16, 2019 at 6:07 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    If you used Maxlife, you're fine. Everybody uses it.
  16. Dec 16, 2019 at 6:52 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Back to the orig. post, "ever since I installed the camper shell". He said nothing about lost mpg. after installing 33" tires. He never mentioned lowering the air pressure to 29 psi., probably been like that all the time. Surely the trans. fluid & diff. fluid didn't go bad right when he installed the camper shell. If wheel bearings are bad enough to lose 30% of your fuel mi., you will know it pretty quick, with that much drag, the heat in the bearing will probably melt the hub, before a tank of fuel. Just a fact, a faulty oxygen sensor can cause a drastic loss of mpg. Most local parts store should check that for you free, but the odds are against an oxygen sensor going bad right when you install a camper shell. I agree, installing the camper shell shouldn't effect the mpg. that much, but to be sure, remove it & run a tank or two of gas, to see if mpg. goes back up. Good luck, & let us know what you figured out.
  17. Dec 16, 2019 at 6:59 AM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    I run 35PSI. 29 sounds low. The camper shell, 33s, winter gas, winter driving conditions and winter warm up times are all mileage killers.
  18. Dec 16, 2019 at 7:23 AM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I had never thought about the winter blend fuel. Maybe that's why my MPG seems to be about 1 MPG lower than usual. I'm only getting 14 with my camper and 305s.
  19. Dec 16, 2019 at 7:24 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Odometer would still be accurate regardless of tire size since it gets its input from the vehicle speed sensor and/or turbine speed sensor inside the transmission, whereas the speedometer gets its information from the wheel speed sensors (and hydraulic brake booster). The transmission rotates based on engine RPMs (throttle inputs, etc..) and is independent upon wheel size, mainly getting its input off of engine load. The wheel speed sensors on all 4 wheel hubs will change depending on how fast the tire is rotating based on size/diameter which is why it is suggested to get a calibrator to "fix" the signal and give you a more accurate reading on your speedometer. I run the Hypertech Inline Calibrator which intercepts the wrong speed signal and does the math for be before sending it to the speedometer. Others have used a Scangauge to do this so you'll have some options.
    -J
  20. Dec 16, 2019 at 7:38 AM
    Muddinfun
    Muddinfun Well-Known Member
    You really shouldn’t post before you drink your coffee.
