Horrible knocking sound from front passenger side
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tampon4x4, Mar 27, 2023.
  1. Mar 27, 2023 at 9:03 PM
    Tampon4x4
    Tampon4x4 [OP] Active Member
    2023 tacoma trd offroad
    Fox 2.5 race series RR coilover shocks, Fox 2.5 race series RR shocks, UCA total chaos, deaver springs, 32" tires, 704 method wheels
    I have a 2023 Tacoma Trd off-road with 5k miles on it. A few weeks ago a shop installed Fox race series RR shocks front & back with a 2” lift. Deaver springs, Total chaos UCA, 32” tires & 704 method wheels. A few days after it was finished a horrible knocking sound started. It’s mainly in the front passenger side. I can feel it in the floor every time it does it. Took it back to the shop 4 times. Replaced the UCA’s twice still does it. The shop is at a loss & says it’s “safe” to drive. It occurs every time I reverse, accelerate or decelerate. From 2mph to 75mph. It’s worse at lower speeds but I feel it more going faster. Its more severe going straight & it’s never just one clunk it’s multiples every time & they vary in sound. It seems like the truck is going to fall apart. Any ideas??
    MGMDesertTaco likes this.
  2. Mar 27, 2023 at 9:07 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Welcome to the site Tampon!
    If you were to be driving ~10mph or so and the gas, let off, tap the gas, etc. does it make the clunk every time? Still have the sway bar on? Have you looked for anything rubbing?
  3. Mar 27, 2023 at 9:08 PM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Can’t say I have any good ideas but do you still have the OEM wheels/tires? If so, throw them back on and see if it still does it. did they put on a diff drop kit? Maybe they forgot a spacer or somethings not tight.
    I’d also suggest maybe checking out the regional thread you’re in and see if there is another shop to try out for diagnostic.
  4. Mar 27, 2023 at 9:16 PM
    Tampon4x4
    Thank you! Yes, it still clunks doing that. I still have the sway bar & there’s no wear on anything that I’ve seen. It makes no sense
  5. Mar 27, 2023 at 9:19 PM
    Tampon4x4
    When I first took it into the shop they put the OEM wheels/tires back on & it still did it. They didn’t install a diff drop kit because I only lifted it 2”. The shop has no clue what it could be but it didn’t start until after they modified it
  6. Mar 27, 2023 at 9:20 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Where are you located? Might be time to have a different shop take a look. What you’re describing doesn’t follow typical things that occur during a suspension install so something might be loose or making contact. It would likely take a different set of eyes to look for signs of what’s wrong.
  7. Mar 27, 2023 at 9:22 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Mine does it too, especially when turning right at low speeds. Started after my lift and goes away when it’s warm out. Getting bigger tires also made it less frequent. It’s a truck and you’ve modified the suspension geometry, as long as nothing looks broken, is contacting metal on metal, or unsafe I wouldn’t worry about it.
    I also changed my radiator bushing with the energy suspension harder ones and the sheet metal above them is cracked so I tell myself it’s that.
  8. Mar 27, 2023 at 9:23 PM
    AmateurTaco1313
    ROK
    Enough for now
    Also check your LCA bushings, could be that
  9. Mar 27, 2023 at 9:23 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Check your dust guard for your passenger side brake rotor. It may have gotten bent inward and hitting it. Also show me a pic of your passenger side in front of the tire towards the inside underneath of the truck.
    SWPA Tacoma and AmateurTaco1313 like this.
  10. Mar 27, 2023 at 9:24 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This site is full of tampons , welcome
  11. Mar 27, 2023 at 9:28 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    @Tampon4x4 titles like "help me" are usually for people stranded. welcome to the site!
  12. Mar 27, 2023 at 9:31 PM
    erok81
    Imposter
    Yeah but a knocking noise everytime you tap the gas or brake isn’t normal. Sounds more like something is loose.
  13. Mar 27, 2023 at 9:31 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    A 2023 shouldn’t be making any noises after a simple suspension install. Have someone else take a look. If something is found, go back to the shop you paid for a service to properly address it.
  14. Mar 27, 2023 at 9:32 PM
    erok81
    Imposter
    If you are constant on the gas and hit a bump does it make make be same sound? Or only off and on the gas?
  15. Mar 27, 2023 at 9:49 PM
    Tampon4x4
    Mine doesn’t go away with weather it’s consistent. A truck should not be making a brutal knocking sound after upgrading the suspension. The issue is nobody knows what it is so I don’t know if it’s safe or unsafe. haha you might want to look at it again to make sure you’re safe too!
  16. Mar 27, 2023 at 9:52 PM
    Tampon4x4
    It makes the same sound constant on the gas going over bumps, going over flat roads, turning etc
  17. Mar 27, 2023 at 9:52 PM
    erok81
    Imposter
    Okay last one. What if you are stopped and turn back and forth? Any noises during that?
  18. Mar 27, 2023 at 9:53 PM
    Tampon4x4
    With the sound it’s making I might be stranded soon! Thank you :)
    tcBob[QUOTED] and erok81 like this.
  19. Mar 27, 2023 at 9:54 PM
    MGMDesertTaco
  20. Mar 27, 2023 at 9:56 PM
    MGMDesertTaco
    CV axle loose?
    ToyoTaco25 likes this.
