Horrible metallic dragging sound from underneath truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eccracer104, May 3, 2011.
  1. May 3, 2011 at 2:52 PM
    eccracer104
    eccracer104 [OP] O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Driving home from school today I had my music turned up pretty high so I didn't hear this sound until just before I got home, so I'm not sure how long or when it started but here's the issue-
    -Coming from somewhere underneath the truck there's a sound as if something is being dragged. The sound is identical to what it would be like if the cable that holds the spare tire was dangling and the metal plate was dragging on the ground. That was my first guess, then I saw my spare tire so continued to inspect and saw nothing dragging, nor any obvious issues that would cause this sound.
    I know this is difficult to diagnose but any help on what to do or check would be great! I can take pictures if need be and post some shots of underneath of it will help.
    Thanks all!
    -Mike
  2. May 3, 2011 at 2:59 PM
    ink junky
    ink junky I love tacos too!!!
    TACO LOVER
    TEXAS
    2010 4x4 trd off road DC,
    Aero turbine 2525, Snorkel, AFE pro dry drop in filter, BFG 33s, spydertraxwheel spacers :/. Debadged, rebadged black, TW sticker :D, bed lights, rod holders, OEM roof rack, Complete OME lift, bed lined fenders. Armor Tech Off road wrap around HC rear bumper w/ tire carrier swing out. Relentless front aluminum bumper. Le Devil Horns (_)
    something grinding against the brake discs in the front?
    Something making contact with the drive shaft that shouldn't?
  3. May 3, 2011 at 3:02 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    Ran over the Tin man?
  4. May 3, 2011 at 3:02 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    x2^^^^^^^^^^^^^^^^
    wheel bearings
  5. May 3, 2011 at 4:38 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    A co-worker drives an F-150 and had the same experience - his wheel bearings were shot. Might be worth a look. Does the sound get worse when turning?
  6. May 4, 2011 at 6:17 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    ditto from above...brake pad, brake shield, wheel bearings.
    may also want to get someone else to drive it slowly while you walk around the vehicle to pinpoint it better.
  7. May 4, 2011 at 6:22 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i was thinking more along the lines of getting your self a harness and dangle yourself under the truck mission impossible style.... but walking works too.
  8. May 4, 2011 at 6:39 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I had a bad grinding sound in my '07, it turned out to be a heat shield that got loose and was rubbing. I agree with jhodge, have someone drive it slow so you can pinpoint the noise.
  9. May 4, 2011 at 6:40 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    fixed.
  10. May 4, 2011 at 6:45 AM
    Pugga
    Massachusetts
    :thumbsup:
  11. May 4, 2011 at 6:46 AM
    The_Hodge
    SC
    i got multiple small rocks between my heat shield and rotor...worst noise ever.
  12. May 4, 2011 at 6:47 AM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Neighbors mailbox?...
  13. May 4, 2011 at 7:55 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Is the tin man alive???
  14. May 4, 2011 at 8:45 AM
    ink junky
    TACO LOVER
    TEXAS
    update?...
  15. May 4, 2011 at 10:52 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Sorry for no updatesyet, I've been driving my girls bmw x3 which is pretty fun! The tin man is ok, i dumped him off at the ICU, not my problem anymore :p and I'm already in the process of constructing my hanging device for mission impossible... are you saying having a second person would be easier AND safer?
    -Back on track... It is speed related as in the sound changes with my speed. I'm going to put some grease on my driveshaft around the carrier bearing and see if that changes anything at all, also planning on pulling a wheel to check my brake pads. If it is my wheel bearing, any tips to check it?
    Later today Ill have someone drive my truck while i walk aside to listen to it.
  16. May 4, 2011 at 11:09 AM
    bluetaco80
    bluetaco80 Well-Known Member
    Rob
    fullerton ca
    06 prerunner dc sb longtravel
    Full engage longtravel front and rear
    I had a bad sound under my truck and firgured out it was a u-joint in the driveshaft needed to be replased, it sounded like metal was dragging.
  17. May 4, 2011 at 11:09 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    jack up truck and try n wiggle tire from top n bottom
  18. May 4, 2011 at 11:13 AM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Jack up, and perform wiggle check. Got it. Thanks for the help so far everyone. I'll letcha guys know what happens when I get a chance to check it over
  19. May 4, 2011 at 11:14 AM
    river rat 69
    Jim
    007, trd, sr5, fmf.
    X2 you beat me to it!!! Little movement is ok but over 3/16 1/4 no,, barring is shot out
  20. May 4, 2011 at 11:32 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    hey mike i had a similar sound that would annoy the shit outta me going hand in hand with my rpm's right around 1500 is when it would be the worst.I found out my gasket was gone so i put a new one on it, same sound. then i took it apart and welded the exhaust and thought i had the last laugh but it still did it! turns out i finally just bought a new flowmaster and put it on and it stopped. must have been a loose screen thing in the muffler, what kind do you have?
