Horrible Screeching/Grinding Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zednix, Jul 6, 2014.
  1. Jul 6, 2014 at 3:56 PM
    Zednix
    Zednix [OP] Well-Known Member
    Edmonton, Alberta, Canada
    14 TRD Sport
    I went out to do some errands this morning and A few blocks from my house I notice this strange screech/grind sound coming from my driver side, I couldn't quite make it out over the sound of my truck running.
    I had been driving the truck for roughly an hour before I noticed any strange sounds, having stopped in at a few stores with no issue until this point. When it came to parking at home the sound was horrible and loud. It is louder in reverse than in drive.
    I am uploading a video of what this sounds like and I will link it below. I am getting my truck into the nearest Toyota(dealer purchased from) tomorrow morning to get looked at. Any experience with something like this would be appreciated.
    https://drive.google.com/file/d/0B7BrIBqSw2ckOUVQUktMX25OZGM/edit?usp=sharing
  2. Jul 6, 2014 at 4:04 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Sounds like the front brake backing plates hitting the rotors. Try crawling under and pull them back a little.
  3. Jul 6, 2014 at 4:05 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Damn, that sounds nasty. Did you crawl under the truck and have a look around?
  4. Jul 6, 2014 at 4:07 PM
    Zednix
    14 TRD Sport
    I haven't taken a look underneath. I will go out and have a look and see if my brake is stuck to the rotor. I don't have a lot of knowledge in this area, I have only installed breaks/rotors once on a VW Golf. If I see something weird I will take pictures.
  5. Jul 6, 2014 at 4:10 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Your truck is still pretty new but you should still jack it up (on a good jack not the crappy bottle jack) and try and shake that wheel if it has any play you could have a bad wheel bearing.
  6. Jul 6, 2014 at 4:15 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Not the brake to the rotor but the tin plate on the backside may be bent and scraping along the edge of the rotor (ask me how I know) With your fingers just pull it inward toward the center of the truck and away from the rotor the best you can.
  7. Jul 6, 2014 at 4:19 PM
    Zednix
    14 TRD Sport
    I took a look and I really have no idea what I'm doing. Both fronts look the same, meaning there isn't any difference to me on the surface. I did look at that weird tin plate thing and didn't notice that it was bent any which way. Would driving it over a few bumps do any good or is that just a bad thought.
  8. Jul 6, 2014 at 4:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Bad wheel bearing or brake shims positioned as they not need be.
    If you are capable of jacking the truck up, do so and attempt to manually roll the wheel. If you can still hear it both frontwards and backwards it's going to be the brake pad shims. If you can wiggle the entire wheel assembly and can see/feel wiggle, you have a bad wheel bearing.
    Good luck.
  9. Jul 6, 2014 at 4:24 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    It's a new truck. Just take it back to your dealer. You paid enough for it. Let Toyota get their hands dirty.
  10. Jul 6, 2014 at 4:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Or you can do that too. If you have the technical knowledge, then it all comes down to the question of just how much your time is worth.
  11. Jul 6, 2014 at 4:33 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You should be able to feel if the tin plate is touching the rotor. It doesn't need to be pulled away very far.
    In fact, from the outside looking through the spokes of the wheel you should be able to see if the tin plate is touching. Use a long handled screwdriver to just nudge it away.
  12. Jul 6, 2014 at 4:34 PM
    Zednix
    14 TRD Sport
    Going out for another attempt. Reporting back in a few.
  13. Jul 6, 2014 at 4:43 PM
    bzzr2
    bzzr2 Well-Known Member
    just bring it to dealer so they can tell you they didn't hear anything...! or that it's normal.... but if you have no clue what to look for or whats going on under there bring it in asap.
  14. Jul 6, 2014 at 4:45 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  15. Jul 6, 2014 at 4:48 PM
    Zednix
    14 TRD Sport
    I checked that tin plate on both fronts and it looks ok. I am going into the dealer with it first thing tomorrow morning, thank you for the help anyway.
  16. Jul 6, 2014 at 4:51 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    No problem. Good luck!
  17. Jul 6, 2014 at 4:55 PM
    Zednix
    14 TRD Sport
    I am hoping it wont be a huge problem to fix. I've had the truck for under a month. I am wondering if there is a rock jammed in the rear driver brake. I am debating driving it around the block and seeing if it lets loose over some of the bumps and dips. Not sure if that is a smart idea though.
  18. Jul 6, 2014 at 4:58 PM
    Manwithoutaplan
    ID
    Maybe a wheel bearing which would be odd for truck that new.
  19. Jul 6, 2014 at 5:07 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I'm going to bet a stone... perhaps another reason to pull on the backing plate a little.
  20. Jul 6, 2014 at 5:08 PM
    Manwithoutaplan
    ID
