Horrible Screeching/Grinding Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zednix, Jul 6, 2014.
  1. Jul 6, 2014 at 5:47 PM
    Zednix
    Zednix [OP] Well-Known Member
    Edmonton, Alberta, Canada
    14 TRD Sport
    Took it for a drive around the block, it sounds horrific. It seems to be coming from the rear driver side. The sound increases as you slow down or brake. Taking it in first thing tomorrow.
  2. Jul 6, 2014 at 5:51 PM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Then that would indicate it's more likely an issue you won't necessarily be able to check without taking the brake drum off....
    Also, sub'd to hear the outcome; I have a 2014 too and am curious what it is.
  3. Jul 6, 2014 at 5:57 PM
    Shiloh1944
    Shiloh1944 Active Member
    Louis
    Texas
    Tacoma TRD off road
    AVS Bugdeflector II, AVS Window Rain Guards, Clazzio leather seat covers, Polk Audio door speakers, Kicker Hidaway powered sub. Auto dimming mirror/compass and temp.
    I am with Stevens104X4. I think it is a stone lodged against the brake rotor. I had that happen to a Tundra I once owned. Made a terrible noise until the stone dislodged.
  4. Jul 6, 2014 at 6:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It is a lodged stone. I agree with Shiloh1944. Without pulling off that drum there is nothing you can actually do about it.
  5. Jul 6, 2014 at 7:10 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
  6. Jul 6, 2014 at 10:30 PM
    Zednix
    14 TRD Sport
    I'm taking my truck in bright an early tomorrow. I am going to be late for work but I can't get to work without a vehicle. This week has been a string of bad luck for me.
  7. Jul 7, 2014 at 2:31 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it is in the rear, there isn't any way for a stone to get in...
  8. Jul 7, 2014 at 9:03 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Stone between the rotor and the rotor shield fairly common and damn noisy.
  9. Jul 7, 2014 at 3:48 PM
    Zednix
    14 TRD Sport
  10. Jul 7, 2014 at 3:59 PM
    Manwithoutaplan
    ID
    RE tube the bastard and put some splines on it :D.
  11. Jul 7, 2014 at 4:06 PM
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    I'll bite....how the hell did the heat shield get bent?!?
  12. Jul 7, 2014 at 4:09 PM
    Zednix
    14 TRD Sport
    2x4 hopped up off the road and nailed it.
  13. Jul 7, 2014 at 4:11 PM
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    Ah...I was trying to form the connection between the two lol.
    Glad to hear it got worked out...no long term worries you think?
  14. Jul 7, 2014 at 4:42 PM
    F75gunslinger
    Christian
    Rochester,NY
    As an aside...paint the driveshaft...primer then paint...clean metal will rust like hell.
  15. Jul 7, 2014 at 5:06 PM
    #35
    Zednix
    14 TRD Sport
    This will be something to get done this weekend.
  16. Jul 7, 2014 at 5:10 PM
    #36
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Well I'll be. Way to go. Now change the rear diff oil over to synthetic for shits and giggles. Thanks for sharing! Unbelievable.
