Horrible sound when I crank my truck up
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ga.boy, Feb 10, 2016.
  1. Feb 10, 2016 at 11:07 PM
    Ga.boy
    Ga.boy [OP] Member
    Dalton
    2003 Tacoma 3.4 v6 TRD
    31 inch nitto terror grapplers, Americas rims and jvc touchscreen radio
    I have a 2003 Tacoma 3.4 double cab. Everytime I crank it up the belt starts to make this horrible noise. Does anyone have any suggestions?
  2. Feb 10, 2016 at 11:33 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Describe it. Like a squeal?
  3. Feb 11, 2016 at 2:56 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    You have tried to tighten your belts right?
    SnowroxKT likes this.
  4. Feb 11, 2016 at 3:18 AM
    Stags863
    Stags863 Bye Felica!
    Florida
    2014 DCSB TRD Off Road 4x4
    - Bilstein 5100's set at 1.75 - 265/70/r17 Goodyear Wrangler Authorities - 6000k headlight and fog light bulbs - NiLight off road LED rear lights - Light bar mounted behind front bumper - White LEDs in dome, map, and sun visor - Tint (5% around / 35% front) - Universal 13 inch metal antenna - Beer bottle opener in bed - Organizer storage box in center console and glove compartment - Mounted MagLite to top of center console storage box - MGM grille - MGM rear bumper - CamLocker toolbox - Rubber floor mats - 2 USB and Cig lighter chargers in rear of center console - Headrest mounted iPad holders for rear seats
    Need a little more info. What does the horrible sound sound like?
  5. Feb 11, 2016 at 7:47 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    guess we dont get anymore info;)
    Stags863[QUOTED] likes this.
  6. Feb 12, 2016 at 4:31 AM
    Ga.boy
    Ga.boy [OP] Member
    Dalton
    It is a squeal until the truck gets warmed up so it goes one for about one minute
  7. Feb 12, 2016 at 4:32 AM
    Ga.boy
    Ga.boy [OP] Member
    Dalton
    And I've tightened my belt four times but it loosens up everytime I drive it.
  8. Feb 12, 2016 at 5:35 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Sounds like you will have to replace the bolt you are tightening that come loose. Also change the belt?
  9. Feb 12, 2016 at 9:03 AM
    Ga.boy
    Ga.boy [OP] Member
    Dalton
    Ok thanks
  10. Feb 12, 2016 at 12:48 PM
    bry838
    oregon
    Three different belts.
  11. Feb 12, 2016 at 12:50 PM
    wilcam47
    Will
    Bourbon state
    check underhood area for cats;)
  12. Feb 13, 2016 at 9:13 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Or pieces of cats. Cat guts on your belts/pulleys WILL cause them to slip.
    CodeSeven and wilcam47[QUOTED] like this.
  13. Feb 15, 2016 at 9:49 AM
    wilcam47
    Will
    Bourbon state
    Exactly....;)
  14. Feb 15, 2016 at 9:51 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Idler pulley could cause the squeal to. But not usually
  15. Feb 15, 2016 at 9:56 AM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    ME:eek:W !!!
    :rofl:
  16. Feb 15, 2016 at 8:26 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    how bout remove all of your belts and start your truck to see if the noise persists. if not, buy new belts and put the first belt on and try again. if no noise, put second belt on and try again, if no noise put third. if still no noise then your belts were the issue and youre good to go with new belts.:thumbsup:
    if you get noises during the replacement, that component is the issue. noises without any belts on indicates timing issues. replace components.
