Horrible Squeek when turning wheel. HELP! VIDEO.
Discussion in 'Suspension' started by Fisheez, Apr 6, 2011.
  1. Apr 6, 2011 at 10:03 PM
    Fisheez
    Fisheez [OP] Built Ford Tough.
    Zack
    So Cal
    Tacomaless For Now
    Fixed: Replaced wheel bearing and rotors
  2. Apr 6, 2011 at 10:16 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    try taking it to the carwash and pressure wash anything that you sprayed with the wd40 then get some silicone grease and try that.
  3. Apr 6, 2011 at 10:27 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    Will do thank you for chiming in. Is there spray I can buy to substitute putting grease on my finger and spreading it around?
  4. Apr 6, 2011 at 10:50 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    yeah thats what im talking about you can get it at wally world and its in a red can and its just called silicone grease i will see if i can find a picture of it
  5. Apr 6, 2011 at 10:51 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Ya, WD-40 is not a good lubricant. Use a grease.
  6. Apr 6, 2011 at 10:53 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    [​IMG]thats what i have used before it worked on my old truck for sqeaks
  7. Apr 6, 2011 at 10:55 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    White, I know what you're talking about. No need to send a pic. I went to walmart to buy cans of silicone spray that day so I can spray all the suspension, but they were out so I used wd.
    On a side note, solving spray is amazing to use on the black plastic finish on our truck. ie: bed, bumper, trim.
    Thats another reason I love thatstuff
  8. Apr 7, 2011 at 5:22 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That sounds like the rubber at the top and bottom of the coils.
  9. Apr 7, 2011 at 6:50 PM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    ^there is no rubber between the coils.
  10. Apr 7, 2011 at 9:41 PM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Get yourself a mechanics stethoscope:
    http://westsidespearfishing.com/?page_id=3&category=63
    You can pin point the noise.
    It's really hard to tell just by a video.
    Also turning you wheel while at a complete standstill? Not a good idea. Your rack-n-pinion won't be happy!
  11. Apr 8, 2011 at 3:50 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Between the coil and the seat, unless you took it out, it's there.
  12. Apr 8, 2011 at 11:43 AM
    Fisheez
    Zack
    So Cal
    Tacomaless For Now
    I've got coilovers amigo.
  13. Apr 8, 2011 at 11:46 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    we started hearing a noise like that when we took the sway bar off of my buddies ford, we got silicone spray for the joints and haven't heard the noise since.
  14. Apr 11, 2011 at 5:47 PM
    mnudo200827
    mnudo200827 Well-Known Member
    Michael
    Corona, CA
    2005 Tacoma Double Cab Prerunner
    Icon Coilovers, All-Pro UCA's, All Pro 3" Leaf Springs, Rear Fox Adjustable Shocks, Stainless Steel Brake lines, 17" KMC Addicts wrapped in 305/65/17 KM2's, Kenwood DDX 512 stereo, 2 12" Polk Audio MM1240 subs in custom enclosure, 4 component speakers, Wet Okole Seat Covers
    sounds like it was the uniball on the UCA. Mine made the same squeaking noise and i sprayed the uniball and it went away.
  15. Apr 12, 2011 at 1:02 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    its your uniballs..spray with dry teflon spray, available at lowes or homedepot
  16. Apr 13, 2011 at 2:32 PM
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    That is exactly the same noise my wifes honda accord was making. I started replacing everything I could that I thought could be causing the sound. The last thing I replaced with the LOWER BALL JOINT and it solved the problem.
    CHECK YOUR BALL JOINTS! ONE OR BOTH ARE SHOT!
    It's most likely your lower.
