Horrible steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jdgshred, Apr 11, 2021.
  1. Apr 11, 2021 at 3:27 PM
    Jdgshred
    Jdgshred [OP] Member
    I have an 09 Tacoma with 150,000 miles. I’ve noticed loose steering, steering not returning to center. When I go over bumps or cracks in the road it feels as if the steering disconnects. It is not the typical “drop” sensation in the steering that Tacoma’s have. I can feel every road imperfection in the steering wheel (which was not there before). There’s also weird feelings in the brake pedal during breaking. When I jack it up, I can bot find any play in either of the front wheels. Everything is also 100 times amplified off road. Anybody have an idea or suggestion to look at?
  2. Apr 11, 2021 at 3:29 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Have the alignment checked to see if caster way out on the low side.
  3. Apr 11, 2021 at 3:39 PM
    Jdgshred
    Would that cause all the feelings in the steering wheel? I also have been getting bad tire wear specifically on outer edge of the tire.
  4. Apr 11, 2021 at 3:43 PM
    gotoman1969
    Yes. Very low caster will make the truck feel very light. It will feel like it wants wander on the road, follow the ridges and dips. Steering will not want to center. You’ll get bump steer with pot holes. If you checked everything and nothing feels loose or has excessive play. That’s where I’d start.
