Horrible Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MacTaco, May 10, 2009.
  1. May 10, 2009 at 5:37 PM
    MacTaco
    MacTaco [OP] Mustache May
    Pensacola, Florida
    06 Indigo, Lifted, Flowmaster
    Skyjacker 3" Lift, 285/75/R16 Toyo M/T tires/ Eagle Alloy Wheels, Flowmaster 50 Series, Pioneer Din Head Unit, Viper Alarm/Remote Start System, Debadged, DT Headers, True Flow Intake
    I need to diagnose what is going on with my truck.
    I had my tires rotated this week, and noticed a noise that sounded somewhere between scraping/grinding in the front right area of the truck. It was only when I began to accelerate and then it would stop after around 5 mph. I thought it was probably just the wheel touching the brake caliper a little bit. That was Tuesday I think(also changed my oil that day)
    The sound went away. But now I have a different problem.
    Yesterday I drove my truck, and when I began to accelerate above 1500, the whole truck began to shake. Not like tires out of balance shake. But a horrid shaking. I can't pinpoint where the vibration could be coming from.
    It seems to get worse with higher speed, and only occurs when I throttle it. It doesn't happen in neutral, and doesn't happen when I let off the gas.
    Could it be transmission, or the driveshaft?
  2. May 10, 2009 at 5:39 PM
    TheKneeBiter
    TheKneeBiter Active Member
    check your motor mounts
  3. May 10, 2009 at 5:40 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
    check the tires to make sure you put the lug nuts on correct because it sounds like the front rim did not get put on correct
  4. May 10, 2009 at 5:41 PM
    MacTaco
    Pensacola, Florida
    My first action is to take it back in to the shop, and get them to remove and balance the tires. I'm gonna do that tomorrow morning.
  5. May 10, 2009 at 5:41 PM
    MacTaco
    Pensacola, Florida
    I re-tightened all of the lug nuts last night, and all of them were fine.
  6. May 10, 2009 at 5:42 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    almost sounds like carrier bearing.buddy had a nissan did the same shake.if it is i woulnt drive it far at all.if u do, drive slow to a garage to have fixed or do it your self.
  7. May 10, 2009 at 5:44 PM
    HBtacoma
    HBtacoma SoCal Tacomas
    Oscar
    Huntington Beach
    || Deep Black Custom Paint By DUPONT FINISHES w/ Custom Airbrush Artwork || RCD 4.5 Inch Lift Kit || 20x10 Black XD Monster Wheels w/ Toyo MT 33x12.5x20 Tires || SATOSHI Grill || URD TCAI || Flowmaster 40 series dual exhaust || Pioneer AVIC-D3 w/ Bluetooth and Ipod || JL Audio 500/1 and 12" Kicker Sub || FJ 60 Toyota Emblem Painted Red || Black Custom Leather Interior w/graphite perforated body w/Red Double Stiching and TRD Logo || Leather Arm Rest Mod || T-REX Angry Eyelids || 20% Tinted Windows || Black Altezza Taillights || BHLM Headlights || LED Dome Light || LED Map Lights || HID 35w 6000k || Yellow Tinted Fogs || Nokya 2500k_55w Fog Lights || Painted Engine Cover || Bed Extender || Epic Indust. Bed Bar w/Fog Lamps Tinted Yellow ||
    same here, after i got my lift i had some vibrations while driving around 40 so the guy at the shop recomended i go and get a high speed balance. hopefully it taked care the problem
  8. May 10, 2009 at 5:45 PM
    MacTaco
    Pensacola, Florida
    I saw in another post that the dealership loosened the u-joint, shook it around, tightened it down, and it helped with some vibration. The carrier bearing is inside the u-joint right?
  9. May 10, 2009 at 5:49 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    no it is the section where the 2 shafts meet.it has a "U" SHAPED bracket that holds it up with a rubber bushing around it.
  10. May 10, 2009 at 5:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If its happening in the front, it could be a CV going out....
  11. May 10, 2009 at 5:52 PM
    MacTaco
    Pensacola, Florida
    Ah. I gotcha. I will keep that in mind.
  12. May 10, 2009 at 5:54 PM
    MacTaco
    Pensacola, Florida
    How would I find out? Anything visually noticeable?
  13. May 10, 2009 at 5:57 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    its easy to check,just grab the shaft right by the cb and try to move it.if the rubber is bad it will move a good bit.sometimes the rubber is not there or sticking out somewhere around the bracket.good luck to ya though
  14. May 10, 2009 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your truck is a 4x4, Grab the front drive shaft, and pull on it....check to see if it moves around..
  15. May 10, 2009 at 5:59 PM
    MacTaco
    Pensacola, Florida
    Prerunner.
  16. May 10, 2009 at 6:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm....Now Im back to being a little puzzeled..
  17. May 10, 2009 at 6:06 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Sounds like the driveshaft, maybe some bad u-joints
  18. May 10, 2009 at 6:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well...thats what I was thinking, but he says its comming from teh front....
  19. May 10, 2009 at 6:10 PM
    MacTaco
    Pensacola, Florida
    No, no. The scraping noise was from the front. I'm not sure where the vibration is coming from. It's vibrating the whole truck.
  20. May 10, 2009 at 6:11 PM
    pataco
    Down by the lake
    05 4x4 trd dc white
    check the cb.
