Horribly degraded performance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotacoma08, Sep 10, 2019.
  1. Sep 11, 2019 at 7:14 PM
    #41
    Yotacoma08
    Yotacoma08 [OP] Cut the corner or do it over again
    Tanner
    Mississippi
    2008 Silver Tacoma Fuel rims
    Fuel rims, black brush guards, blacked out emblems, TRD cold air intake, and interior mods.
    I would just like to say that i appreciate every single one of you for the advice you have given me in an attempt to diagnose this issue. I have narrowed it down to several possible issues and it seems to be a fuel issue or some kind of sensor issue. What I will probably end up doing is replacing the fuel pump regardless if its bad or not considering the truck is well over 300k miles. If it isn't the issue, it will at least give me a firm ground to stand on and far as me knowing that i am getting adequate fuel pressure. Another reason I am going without testing is that many people have suggested fuel pump it will either be the fuel pump or o2 senors that will go first. That is the trouble I am having as well. I realize the truck has many many miles and it can really be anything at this point. I know for a fact that the o2 sensors, fuel pump, VVT solenoids, and injectors are all original on that truck and I am not sure if i should just wing it and go down the line replacing parts or if I should keep busting my hind end on a bulls-eye diagnosis.
  2. Sep 11, 2019 at 7:55 PM
    #42
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Thanks!
    I needed time off for the Hurricane anyways :shrug:
    DVexile, Muddinfun and TnShooter like this.
  3. Sep 11, 2019 at 9:48 PM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Check all vacuum hoses first. Free.Then fuel pump and filter. Filter is not accepting any more visitors. Needs replacement. Then worry about injectors. Clean or add new to regain proper atomization.
    TnShooter likes this.
  4. Sep 11, 2019 at 10:56 PM
    #44
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Of course. I was thinking more along the lines of the condition of the filters being an indicator of the condition of the ocv. They are also easier to get to if I'm not mistaken.
  5. Sep 12, 2019 at 3:27 AM
    #45
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    That was a crazy hurricane. It was initially a Category V4 hurricane, then it was in the process of upgrading to a Category V6. It affected many lives of those directly involved but the main EYE of the storm ended up affecting and temporarily closing a neighborhood library. There were hundreds of books with diagrams floating throughout the neighborhood but fortunately, I heard that none was lost and the library is now open.:anonymous:
    Jimmyh[QUOTED] likes this.
  6. Sep 12, 2019 at 3:49 AM
    #46
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    You mentioned throttle body cleaning. If you did that without removing it a couple of different things could have happened. You could have contaminated the idle control and the air fuel sensor. I would start with replacing air/fuel sensor and o2 sensors. The air/fuel and o2 sensors degrade and significantly effect performance and MPG. This was magnified if you did a throttle body cleaning without remove it to clean it. Good luck.
  7. Sep 12, 2019 at 5:26 AM
    #47
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    ^^^ Wrong.
    12TRDTacoma and Lester Lugnut like this.
  8. Sep 12, 2019 at 6:31 AM
    #48
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I would remove a throttle body to clean in order to have better access to the entire device, but I'm not sure I follow the "contaminated idle control and the air fuel sensor" comment.
    If you are inferring there is an idle control vale - there isn't on the V6 1GR-FE. The engine is drive-by-wire - no mechanical linkage. I would agree that if you were to blast away with Throttle Body Cleaner, you could damage Throttle Body electronics. You lose me with the air fuel sensor comment. I would not indiscriminately replace the upstream/downstream sensors until scanner trim value readings and/or voltage test told me they were bad.
    Jimmyh, Fullboogie and Loco_Barbon like this.
  9. Sep 12, 2019 at 8:39 AM
    #49
    Yotacoma08
    Tanner
    Mississippi
    I did do a voltage check on the o2 sensors through a diagnostic tool. I forgot what bank it was and which sensor but it was after the throttle body cleaning and the voltage was really high. Like 3.5 to 4.0 volts high. I then assumed it the o2 sensor. I did disconnect the battery first and and the voltage went back into the normal range.
  10. Sep 12, 2019 at 9:13 AM
    #50
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Have you ever ran fuel system cleaner before?
  11. Sep 12, 2019 at 9:42 AM
    #51
    Yotacoma08
    Tanner
    Mississippi
    I have ran it through a time or two. Never really noticed a difference probably due to my inconsistency.
  12. Sep 12, 2019 at 9:45 AM
    #52
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    This was my first thought. I have a 2009 DCSB with 275k miles and still running strong. I hope to hear a solution to for future reference (knock on wood).
  13. Sep 12, 2019 at 9:51 AM
    #53
    ARB1977
    North Texas
    I wouldn’t hurt to get a cheap bore scope and look down each cylinder. Did you buy the truck used? If your the original owner kudos to you.
  14. Sep 12, 2019 at 10:35 AM
    #54
    Yotacoma08
    Tanner
    Mississippi
    Does anyone know of a fuel pump pressure tester that will fit a Tacoma.
  15. Sep 12, 2019 at 11:46 AM
    #55
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I've changed out many pumps on guys' trucks, at only 100k. Picked back up a very noticeable amount of lost whp. Worthy investment.
  16. Sep 12, 2019 at 11:47 AM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    www.urdusa.com. They have a fuel rail adapter for a pressure gauge.
  17. Sep 12, 2019 at 12:43 PM
    #57
    Lester Lugnut
  18. Sep 12, 2019 at 3:04 PM
    #58
    Yotacoma08
    Tanner
    Mississippi
    So I spend about $100 to get a master fuel pressure kit from harbor freight and turn out this is my pressure at idle. I didnt bother to drive with it because it was kind of a dead give away. Its low compared to specs. The highest it got was to about 32 psi. Spec calls for around 41 or 42 psi so I'm wonder will 10 or so lower psi really be giving me issues as described?
  19. Sep 12, 2019 at 4:06 PM
    #59
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Your test shows 25% less pressure than it should be.
    Did you preform the test with engine running?
    I believe it is to be tested with the ignition in the “on” position.
    Doesn’t say anything about engine running. That is why I ask.
    There are 2 other thing between the pump and injectors.
    The Fuel Pulsation Damper and the Fuel Pressure Regulator.
    I have no idea what those 2 do when they go “bad”.
    Do they fail to “high pressure” or “low pressure”?
    I’m still going with Fuel Pump.
  20. Sep 12, 2019 at 4:22 PM
    #60
    Yotacoma08
    Tanner
    Mississippi
    I did do it with the engine running. I tried just the "on" position but wasnt getting any readings until I started to turn the motor over. The start up pressure was 45 psi, I released the built up pressure and it was then brought down to 30 to 32 psi. I'm not sure if the was some kind of "priming" thing that doesn't engage until you turn the motor. Other vehicles that I know of show pressure with the key in the "on" position
