Horse trailer towing
Discussion in 'Towing' started by foxchase, Aug 4, 2010.
  1. Aug 4, 2010 at 6:07 AM
    foxchase
    foxchase [OP] New Member
    2003 Tacoma SR5 4x4 2.7liter 4cyl
    brake assist, Class C receiver hitch
    I've just bought a new horse trailer and am about to pull it for the first time with my Tacoma. (2003 4x4 xtr cab 2.7liter 4cylinder). Have brand new brake assist and Class C receiver hitch. The trailer is a 2008 one-horse aluminum. Only weights 1760lbs empty. With horse, I will be pulling (mostly highway miles and one level surfaces...not in mountains or even many hills) 2860lbs. Truck is rated to pull 3500lbs.
    I think I'm ok to do this, but have had so many friends tell me to buy a BIGGER truck. I don't want to sacrifice mileage, just so I can pull a trailer once a week! Also, my great little truck is paid for.
    Question: Would you all agree that towing this trailer, with a live load of about 1100lbs, is safe?
    Question: I read in another posting that I should keep the truck in 4-wheel drive while towing? Is that empty or with the load?
    Question: What's this about letting some of the air out of my tires? Did I also read that?
    I appreciate ALL wise advice. Many thanks for reading and responding!
    pc
  2. Aug 4, 2010 at 6:13 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The truck will be doggy at take off and on hills. The manual tranny will work to your advantage though.
  3. Aug 4, 2010 at 6:15 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Do not tow in 4x4 or air down your tires. Just tow in 4x2 w/ regular tire pressure.
  4. Aug 4, 2010 at 6:21 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Keep tires to mfg specs. You only air down for sand.
    Tow in 2wd unless in snow, mud, gravel, rain.
    Truck will pull fine. You just have to take it easy.
    Hope you have the inertia activated brake controller. Time based ones are crap.
    Do you have the auto trans cooler and upgraded fan clutch?
    Make sure you have the brake-away system for the trailer and that the 12v from the truck is charging it.
    Take it easy, you'll do fine. Just don't expect good mileage while towing.
  5. Aug 4, 2010 at 6:28 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Also, be aware that the shitfing weight of the horses will influence trailer sway and braking. You'll definetly feel them back there.
  6. Aug 4, 2010 at 6:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    He has a manual.
  7. Aug 4, 2010 at 6:32 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Can't see that info from my phone, so I covered all the bases:)
  8. Aug 4, 2010 at 6:37 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
