horsepower/gas mileage increase
Discussion in 'Performance and Tuning' started by eapple, Apr 3, 2013.
  1. Apr 3, 2013 at 10:24 AM
    eapple
    eapple [OP] New Member
    To maximize horsepower and fuel mileage would it be best to install cold air intake with a chip and high flow exhaust?? also how do you determine which chip to install if you change to cold air intake?
  2. Apr 3, 2013 at 10:25 AM
    Large
    Large Red
    No, use less skinny pedal.
  3. Apr 3, 2013 at 11:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Eat "Kettle Brand" Chips.
  4. Apr 3, 2013 at 11:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Need more info about your truck.
  5. Apr 3, 2013 at 11:06 AM
    Large
    Large Red
    This first, but usually the words horsepower and MPG don't go together.
  6. Apr 3, 2013 at 1:03 PM
    Kevoh
    Kevoh Well-Known Member
    Kevoh
    Yorba Linda, CA
    '12 Taco
    a few goodies here and there!
    LOL @ This. Fucking love it lol
  7. Apr 3, 2013 at 8:33 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Get your ECU calibrated don't think you can buy a plastic chip and make your truck basically faster and better mpg
  8. Apr 3, 2013 at 8:50 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The myth that intake and exhaust help mpg is false.
  9. Apr 3, 2013 at 8:53 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    a chip and intake and exhaust will get you substantially more horsepower and mpg after you get a new engine and throw the other stuff away.
    but seriously, chips do crap
    intakes are usually crap
    exhausts get minimal gains
    forced induction is the only real way to get a noticeable gain, but then bye bye mpgs, cause you don't buy a corvette to watch grass grow
  10. Apr 3, 2013 at 8:59 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    I am going all in on horse power. And could give a shit about gas mileage. You will gain nothing size able or noticeable unless you put down 2k+ and then you can start burning more dead dinosaur juices.
  11. Apr 3, 2013 at 9:08 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Increase in HP=Trade Taco for Tundra:D
    Increase in MPG=Trade Taco for Corolla.
    Best compromise is probably a supercharger. But then, who cares about MPG. Cost of supercharger will pay for lots of gas. On second thought, leave it stock. Toyota spent lots of money engineering a decent compromise.:cool:
  12. Apr 4, 2013 at 4:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get a EMS, and tune it to have a little more timing than stock, and run a little leaner than stock.
    Add cam gears to cool the combustion chamber and evacuate the exhaust gases more quickly. To help with previous comment about EMS.
  13. Apr 4, 2013 at 7:13 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Wait what?
  14. Apr 4, 2013 at 1:13 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    I meant the MAF.
    because everyone on Tacomaworld loves to jump on the first guy who makes a mistake :rolleyes:
  15. Apr 5, 2013 at 3:29 AM
    eapple
    it is a 2007 tacoma double cab ... completely stock. I pull a camper and really just looking for a little more hp only reason i even mentioned gas mileage is the last mustang i had when i put cold air intake on the mpg increased for all these smart@sses on here!!!
  16. Apr 5, 2013 at 3:38 AM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Yeah... Apples to oranges. Get a lighter rim and tire combo to reduce rotating mass.
  17. Apr 5, 2013 at 3:56 AM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    not really gonna happen in these trucks... Sorry bud
  18. Apr 5, 2013 at 7:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You'll definitely pick up power with an Afe or URD intake. Gas mileage will be most dependant on gas pedal, tire pressure and all sorts of other factors.
  19. Apr 8, 2013 at 1:01 PM
    TacoOwner
    TacoOwner Member
    Pat
    California
    Dbl Cab Short Bed 4X4
    Pro-Comp 6" Lift/33" Wranglers/Detroit TrueTrac Diff
    I have a 2011 V6 Taco 6" lift. Avg mileage 18-20. I didn't see any improvement after intake/exhaust changes, until I changed the clutch fan to an electric and got a BullyDog Watch dog to show me where I was wasting fuel.
    PS. I have Manual Trans. I don't think you can get this mileage with a Auto.
    Hope that helps.
  20. Apr 8, 2013 at 1:08 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
