Hoses to replace when changing valve cover gaskets
Discussion in '1st Gen. Tacomas (1995-2004)' started by Corn, Apr 6, 2013.
  1. Apr 6, 2013 at 7:10 AM
    Corn
    Corn [OP] Active Member
    00' Tacoma 4x4 ext. cab 3.4 ltr
    Fog lights added in 2002
    2000 Tacoma 3.4 V6 4WD
    Could you guys help me in determining which hoses to replace when I replace the valve cover gaskets.
    I would like to have some replacement hoses ready before I start, so when I start taking hose connections apart and they are cracked -due to being 13 years old- I can replace them without leaving the engine wide open for days.
    If you have experience in changing the valve gaskets, and know which hoses need to be removed in order to remove the plenum, etc. (so I can go to the parts store and ask for these ___ hoses) could you give me a list and or a pic?
    Note: I've already replaced the PCV valve and it's hose.
    Thanks :cool:
  2. Apr 7, 2013 at 7:25 AM
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I just had both of my valve covers off 4-5 times in the last week or two. (long story)
    I had no issues with any of the hoses to the point where i'd want to spend the cash to replace them. What i would do, is spend some time under the hood with a flashlight and look at the large double walled hose that 'clips' into the mount on the top of the plenum, and connects to the the bung closest to the throttle body, on the firewall side of the intake. That's the only one i considered replacing due to wear, but Toyota wanted ~$22 for the hose and it really wasn't that bad... so i skipped it.
    Did you use an OEM toyota PCV valve or did you go with an Autozone generic? Reason being, my off-brand PCV valve was a piece of crap. For about 3$ more, you get a beefy, metal, OEM PCV valve. I would also order the upper and lower plenum gaskets. Get the good quality, three layer ones as well. Air leaks suck. And make sure you take your time when pulling off and putting back on the passenger side cover, there's a tab between the front two cyl's that you don't want to bend.
  3. Apr 8, 2013 at 7:36 PM
    Corn
    Thanks for that info. I used Toyota parts (made in Japan) for the PCV valve and hose. I also plan on using Toyota parts for the gaskets as well. It's literally about 110$ for the gaskets/plenum gaskets/nut gaskets/spark plug gaskets--and apparently the Toyota valve gaskets are meant to expand so you don't need that silicon shit in the 90 degree angles. Those Toyota factory hoses that are angled for correct routing can be pricey though. I'll spend some more time figuring out any hoses. As of now I don't have the Toyota Haynes repair manual yet. I'm sure it will have diagrams of the engine, etc.
  4. Apr 8, 2013 at 11:39 PM
    MEDICDUDE423
    MEDICDUDE423 Well-Known Member
    East TN
    03 Tacoma Limited X-Cab 4WD
    After you figure out the hoses you are going to replace post a few pics if you can, I have the complete wiring diagram, post up which ones you need and ill pin them up
  5. Apr 9, 2013 at 10:44 AM
    Corn
    Thanks. May be a while, but I will.
  6. Apr 17, 2013 at 9:30 AM
    Corn
    I will try and replace most of these hoses. The key ones will be located underneath the throttle body/plenum located in the close-ups. Also attached a general over view pic. Thanks
  7. Apr 22, 2013 at 2:54 PM
    vicstacoma
    vicstacoma Well-Known Member
    Victor
    Santa Maria, CA
    2000 Sr5 4x4
    Air raid cold air intake, procomp 7089 16x8 wheels, bf goodrich all terrain ko 265/75r16. Toytec 3" lift kit. Power slot rotors with posiquiet ceramics pads. Diff breather mod. LR Upper Control Arms.
    I just did my valve cover gaskets in Friday and none of my vacuum hoses were damaged so I didn't replace any of them. I've read that some people don't replace the spark plug seals that go on the valve cover gasket cause it's a pain to get them off, but once you remove one of them the rest are a piece of cake. I just used a small screw driver and a small hammer to tap them out of there. Also when you install the new ones make sure you install them the correct way because they will fit on there the wrong way.
  8. Apr 22, 2013 at 6:06 PM
    boshak
    boshak Well-Known Member
    Tony
    Southern California
    2003 Manual 4x4 5VZ-FE
    OME 881's, Wheeler's 5-leaf pack, Bilstein 5100's
    Only hose I had to replace was to the PCV valve. In addition, I would personally do the spark plug seals while you're in there, they're really not that much of a bear... Just need some vise grips and a 32mm socket to get the new ones in.
    Other things to really consider: plenum gaskets, throttle body gasket, valve cover bolt washers/gaskets, cam plugs, inspect valve clearances. I cleaned TB, MAF, plenums, and changed spark plugs and wires while I was in there too.
    Good luck!
  9. Apr 22, 2013 at 7:21 PM
    Moco
    Moco Well-Known Member
    Eric
    NoVA
    96 Regular Cab 4x4 5spd
    From what I can see in those pics, none of those hoses need replacing.
