Hot and Cold backwards???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Flash, Nov 18, 2011.
  1. Nov 18, 2011 at 1:20 PM
    Flash
    Flash [OP] Member
    Kyle
    Weatherford TX
    2013 Taco
    Old Man EMU suspension, ARB Front Bumper with Warn 9K winch, Safariland snorkel, 33" BFG TKO2's, Road Armor rear bumper with tire swing arm, rear diff breather relocation.
    ...so I posted here before about my climate controls being messed up...got the whole new piece in, got the black trim around the vents and all now like the 2012 tacomas, which looks great, but the entire piece came off a 2006 Tacoma....put it all together works great, except the hot and cold are backwards.=/ I seriously feel I have let my Tacoma down haha but Im getting frustrated with it and dont want to drive it into a brick wall.=D Any ideas why they would be backwards, the dial spins the same way for my 2011, so I dont think its a hardware issuse, but I dont know.
  2. Nov 18, 2011 at 2:36 PM
    Syncros
    Syncros Well-Known Member
    Couldn't you pull the knob off and clock it? (wow that sounds dirty)
    or am I high.
  3. Nov 18, 2011 at 2:38 PM
    Flash
    Flash [OP] Member
    Kyle
    Weatherford TX
    2013 Taco
    I think your high...I have no clue what your even saying.lol
  4. Nov 19, 2011 at 10:16 AM
    JKD
    JKD Well-Known Member
    Based on information I read about the external air temp sensor and the temp/compass display, there were some fairly significant changes to the HVAC control system in around '09. I'm surprised that the '06 control panel works in your '11 at all.
  5. Nov 20, 2011 at 1:54 PM
    Flash
    Flash [OP] Member
    Kyle
    Weatherford TX
    2013 Taco
    Its not the compass and HUD on the top of the cab, its the controls that make the air hot, or the air cold. haha
  6. Nov 20, 2011 at 2:12 PM
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    The newer model 09+ Tacomas use the temp sensor for the A/C unit to power the temp display on the console as mentioned in the previous post. I believe there is also a different climate control module in order to use the different sensor. That is why you can't rewire the older roof console to work in the newer Tacomas. Not sure if the different module could be causing your problem- might be just a matter of swapping a wire in your harness. I have Mitchell wiring schematics at work- I will try to have a look and see when I am at work tonight.
  7. Nov 20, 2011 at 3:16 PM
    JKD
    I know. The HVAC computer (they call it an "amplifier" for some reason) in the '09+ uses inputs from the ambient air sensor, which was altered to communicate in a different way with the compass/temp sensor. They're all talking to each other.
  8. Nov 21, 2011 at 3:34 AM
    84Hilux
    Gary
    Vancouver, Canada
    I looked at the schematics for both these years. The 2011 uses 4 wires to control the airbox mixing solenoid and the 2006 uses 3 wires. As mentioned in the previous post- the 2011 uses an electronic amplifier to drive the solenoid and that is not mentioned in the schematic for the 2006. The simplest driver amplifier would likely be what is called an op-amp inverter and would therefore operate in reverse of a non amplified circuit (just guessing- it is not specified). Not sure if you could reverse the positive and ground in order to solve this problem. It would depend on the configuration of the amplifier. The three wires that are in common in the circuit are wired the same except for the inclusion of the amplifier- the 4th wire in the 2011 is labeled "max" (maybe for the max A/C setting?)
  9. Nov 21, 2011 at 8:38 PM
    Flash
    Flash [OP] Member
    Kyle
    Weatherford TX
    2013 Taco
    Well if I turn it to full heat, the max A/C setting works. Thats what makes no since to me, it came with the 06's wiring connector, but I didnt want to splice up my Tacomas wiring anymore than I did for the illuminating 4x4 switch. Would that fix it if i used the 06 wiring adapter? I dont think it would though...because in the end it would still be the same result, right?
  10. Nov 22, 2011 at 5:29 AM
    84Hilux
    Gary
    Vancouver, Canada
    Probably not- the three wires in common are the same on both years of truck.
  11. Nov 22, 2011 at 11:29 AM
    Flash
    Flash [OP] Member
    Kyle
    Weatherford TX
    2013 Taco
    Dang. I guess I can live with it.lol Just gotta remember the gauge reflects the outside temperature now.=D
