hot rear axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by juice, Jun 2, 2011.
  1. Jun 2, 2011 at 9:28 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    I just made it home from about a 15 mile drive and crawled under my truck to find the rear diff to be very hot. I know its gonna get hot but this seem excessive,so i compared it to the wifes suv that was driven the same distance and its a considerable difference. Any ideas??? Is it the mud tires thats putting the extra resistance one the drivetrain creating more heat? the suv is running streets. thanks for any thoughts
  2. Jun 2, 2011 at 9:33 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Whens the last time you changed your differential fluid?
  3. Jun 2, 2011 at 9:59 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    I checked the fluids after i bought the truck and they looked fresh and clean.idk I may just change it anyway. what additive do i need to add to the diff oil for the e-locker and how much? thanks guys!!!
  4. Jun 2, 2011 at 10:01 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    No additives needed for the elocker. I'm not sure how much off the top of my head, it should be in the owner's manual though if you still have it.
  5. Jun 2, 2011 at 10:02 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Off Roader? Do the differential breather mod! A hot pumpkin dropped in cool water will cause contamination to pass by the axle seals!
  6. Jun 2, 2011 at 10:12 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    the toyota servive guy said it needed a lsd additive to the gear oil. not sure if he really knew what he was talking about. Got to do the breather mod.
  7. Jun 2, 2011 at 10:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    it does not need the additive. You don't have a LSD.
  8. Jun 2, 2011 at 10:16 PM
    kmok
    Kyle
    Columbus, Ohio
    Yeah that guy doesn't know what he's talking about. You don't have a lsd so there's no need for the additive even with the elocker. I've changed the differential fluid in my 03 TRD and all I added was the owner's manual recommended gear oil. Differential breather mod is very easy too.
  9. Jun 2, 2011 at 10:31 PM
    juice
    juice [OP] Member
    covington,la.
    03 sr5 xtra cab trd
    cool, thanks for the info fellas !!!! :D
  10. Jun 3, 2011 at 8:02 AM
    David K
    No, I mean the axle seals...
    Water can't get in through the stock breather as it is a one way check valve that will only let hot gasses out of the differential.
    What the breather mod does is put the breather used on our front differential (which is mounted remote and high up) on the end of a hose off the rear differential, high up.
    This 'front breather' that we also use for the rear mod is a 2 way breather... lets gasses/ air move in or out of the differential. It is now a breather and a vacuum breaker... so, when you drive into deep water (18"+), instead of the the cold water being drawn towards the hot differential (through the axle seals), 'cold' air will break the vacuum created by the temperature difference. This is how it works on the front differential.
    This was all explained in the various rear differential breather mod posts... but maybe not as clearly as I just did here. :)
  11. Jun 3, 2011 at 8:16 AM
    mjohn617
    mjohn617 Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    Ummmm......then why would you bother re-positioning the breather in the first place?
    EDIT:
    Ok so your using the two way in the rear...got it.
  12. Jun 3, 2011 at 8:19 AM
    David K
    To stop the rear differential from being contaminated with muddy water! Happened to my truck when it was only 5 months old going to Mision Santa Maria... Had the differential serviced when I got back because it was dirty. See the MSM photos... http://vivabaja.com/msm2010/
  13. Jun 3, 2011 at 9:54 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    80w-90 gl4 or gl5. Amsoil Severe Gear works well!
  14. Jun 3, 2011 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Mine seems to stay around 170* or so in the summer....As long as its not over 200* everything should be fine.
  15. Jun 3, 2011 at 4:51 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yep x2
  16. Jun 3, 2011 at 6:02 PM
    David K
    Thanks Jerry!
