Hot Rear Drum
Discussion in '1st Gen. Tacomas (1995-2004)' started by JKO1998, Feb 24, 2018.
  1. Feb 24, 2018 at 3:38 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    not from the back side...well you might be able to dislodge it, not 100% certain but then the thing will fall down and could jam up in the rotating drum...
  2. Feb 24, 2018 at 3:39 PM
    JKO1998
    JKO1998 [OP] Well-Known Member
    Utah
    Well the 2 bolt holes in the front that you can use to get it off
  3. Feb 24, 2018 at 3:40 PM
    wilcam47
    Will
    Bourbon state
    if hes trying to loosen it by pushing on the plate and turning the adjuster is should turn freely...
  4. Feb 24, 2018 at 3:42 PM
    JKO1998
    Utah
    I can get the drum about half way off the shoe, but then my bolt runs out. If I get longer bolts can I just pulll it off that way?
    Does that make sense? Using the 2 bolt holes on the front of the drum
    wilcam47 likes this.
  5. Feb 24, 2018 at 3:44 PM
    wilcam47
    Will
    Bourbon state
    should be able to tap it off the rest of the way?
    Running Board Man likes this.
  6. Feb 24, 2018 at 3:44 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Always replace springs when replacing brake linings I've learned. I had a problem in the past once cause by reusing old springs.
  7. Feb 24, 2018 at 3:45 PM
    wilcam47
    Will
    Bourbon state
    how far can you pull your ebrake to set it? it sounds like its way over adjusted/too tight.
  8. Feb 24, 2018 at 3:45 PM
    JKO1998
    Utah
    I haven’t really tried much besides trying to loosen the adjust after that point. I have longer bolt on the way.
  9. Feb 24, 2018 at 3:46 PM
    wilcam47
    Will
    Bourbon state
    the kits are usually cheap also.
  10. Feb 24, 2018 at 3:47 PM
    JKO1998
    Utah
    The springs were replaced, I had a shop donthr axle seals and I think the must have put it back together wrong
  11. Feb 24, 2018 at 4:02 PM
    JKO1998
    Utah
    got the dang thing off, not I gotta figure out how to adjust it.
    I never ever ever use the ebrake, is there a way I can make it not matter so it doesn’t self adjust itself again?
  12. Feb 24, 2018 at 6:12 PM
    JKO1998
    Utah
    Well it’s put back together, drove around the block and it’s still putting off heat, not as much but I didn’t drive as far.
    How much heat does it take to warp a drum?
  13. Feb 25, 2018 at 8:38 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    As soon as I noticed the hot drum, I backed off the adjuster and then reset it so it started to drag, then backed it off until it didn't drag anymore. Sometimes that lasts thru a summer, sometimes not. As I indicated, I still haven't solved the problem.
  14. Feb 25, 2018 at 8:39 AM
    skeezix
    skeezix Ol' Geezer
    1998 Limited
    And then try to fix the problem...;)
  15. Feb 25, 2018 at 8:40 AM
    #35
    jdubdvdt
    jdubdvdt Well-Known Member
    Tampa, FL
    01 4x4 Ext. Cab Impulse Red
    Not sure how much can warp the drum, but I wouldn't want to drive it if it was producing heat.
    Did you loosen the ebrake cable as much as you can with it still able to work?
  16. Feb 25, 2018 at 8:44 AM
    #36
    Itchyfeet
    Itchyfeet Well-Known Member
    I found that aftermarket shoes will drag no matter what. I think they're arched wrong or something which might cause the self adjuster to over adjust
  17. Feb 25, 2018 at 8:46 AM
    #37
    skeezix
    skeezix Ol' Geezer
    1998 Limited
    That's my take on the problem. Right now I have other things to do than to buy a new set of Genuine Toyota Parts brake shoes, and for me, I can back off the adjusters until I get around to buying the shoes and replacing them.
  18. Feb 25, 2018 at 8:50 AM
    #38
    JKO1998
    Utah
    It’s not hot to the touch, I can just throw snow on it and it melts. The other side seems to do the same after I checked again.
    I’ll watch it next time I drive an extended period.
  19. Feb 25, 2018 at 8:53 AM
    #39
    Itchyfeet
    Soon as I took the Centric brand shoes off and installed genuine toyota shoes the problem stopped.
    tony2018 likes this.
  20. Feb 26, 2018 at 7:02 AM
    #40
    skeezix
    skeezix Ol' Geezer
    1998 Limited
