Hot Start AFR?
Discussion in 'Performance and Tuning' started by kigmob, Apr 28, 2014.
  1. Apr 28, 2014 at 11:01 AM
    kigmob
    kigmob [OP] Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Since I've had my AFR gauge, I noticed I go lean (15-15.5) on a hot start. When I start the truck cold, I have a rich ratio (~13.5) which from my understanding is normal. I'm wondering if the lean hot start is normal? This lean hot start condition will lasts while I'm at idle after a hot start. Once I start driving, it goes back to 14.7ish like it should. I have also been having an intermittent hot start problem for the past few months and wonder if this has something to do with it? Could this maybe indicate my IAC isn't working correctly on a hot start? Like maybe the IAC valve is sticking open during a hot start? I'm not sure what the IAC valve is supposed to do on a hot start. Any help is appreciated!
  2. Apr 28, 2014 at 12:28 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    open loop (cold start) and closed loop (hot start). The ecu isnt reading AFR through the o2 sensors until the engine reaches norm operating temp then it goes into closed loop
  3. Apr 28, 2014 at 12:28 PM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Based on my experience, at idle and low rpm my truck is running (at least the monitored cylinder) lean, something like 14.9 to 15.2. On cruise at highway speed, it's running around 14.7.
    Your rich ratio at cold start is normal (first 40 sec approx.) cause you're in open loop in an area that is an electronic emulation of the choke.
  4. Apr 29, 2014 at 5:32 PM
    kigmob
    James
    New Orleans
    I understand this. However, when ever I hot start, my truck is in open loop as well and my afr is lean. I was just wondering if this is normal.
    Thanks for your input. My idle is always at ~14.7 like it should be, EXCEPT when I have a hot start. I am just wondering if anyone else experiences this lean hot start condition like I do.
  5. Aug 7, 2014 at 1:39 PM
    kigmob
    James
    New Orleans
    Bump. Any more input?
  6. Aug 7, 2014 at 9:54 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    The instructions on my wideband says it takes 30 seconds for it to warm up to give a proper reading. There is a good chance you need to let them warm up after a fresh start even though the motor may be warm still. If it stays lean for a long while you might have an air leak after the MAF sensor. Also noted if your short term fuel trims jump all over the place.
  7. Jan 17, 2015 at 11:54 PM
    lovemytacolots
    lovemytacolots Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Hey Kigmob, did you ever get this resolved? I know you've told me on my long, sad thread that fuel pump and regulator fixed your hot start issue, but I noticed this thread and wondered how this resolved.....thanks!
  8. Jan 18, 2015 at 7:49 AM
    MadTaco461
    CA
    Kinda stock
    My truck does the same thing but to a much worse lean afr at hit start. It is because I have the turbo placed before the maf sensor. The maf heat soaks after driving. At hot start my air temp is 120F plus. Once it gets cool air again it settles down. The ecu has some bug in it when your temps get too high it starts trimming fuel like crazy. One way around it with a piggyback is the fuel delivery at idle max your Lt fuel trims to all the way rich. I'm assuming aftermarket intake will have this same issue if you aren't cold air.
  9. Jan 18, 2015 at 12:40 PM
    kigmob
    James
    New Orleans
    It actually still does it but I don't think its an issue. It fixes itself after no more than a minute of idling after I start it. And if I start driving it usually fixes itself even quicker. Still kind of weird it does it, maybe its something the ECU is set to do?
    Thats strange. My MAF is before my S/C so it shouldn't be heat soaking after driving. Unless my engine bay is really hot after driving? I feel like its something normal the ECU does for a hot start. Not sure why. It only last for maybe a minute max for me. So I'm not super worried. And its only at like 15.5 AFR max when it does this. So I think its ok. Just wonder if this is something the ECU is supposed to do or not.
  10. Jan 18, 2015 at 1:01 PM
    MadTaco461
    CA
    Kinda stock
    Mine used to pull air from the fender. Now I pull air under the hood. I hooked an obd 2 up and you can see the fuel trims go weird while the air is hot. Same thing for me it goes away after a minute. My truck is pretty different than stock so I just need to live with it. Mine goes to 19 for a bit but I have larger injectors than stock. Little scary but it is just idle. It won't do it if I pop my hood.
  11. Jan 18, 2015 at 1:05 PM
    kigmob
    James
    New Orleans
    Well thats good to know. I'm gonna try the pop the hood thing. I removed the elbow as well as did the deck plate mod so mine sucks in hot air too.
  12. Jan 20, 2015 at 10:03 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    What are your IAT's at the hot start, before it has had a chance to idle?
  13. Jan 22, 2015 at 9:18 PM
    kigmob
    James
    New Orleans
    I know they are quite warm in the summer. I rarely monitor IAT's this time of year. Im going to check this weekend and let you know.
  14. Jan 24, 2015 at 7:25 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I have to get a A/F gage " would speed up tuning after mods easier" but I have the MAF CAL and I run 10.1 "10 is stock" at idle and it idles much better, I could tell the difference the first time I started it... Over all runs better with a little more fuel at idle..
  15. Jan 29, 2015 at 12:15 PM
    MadTaco461
    CA
    Kinda stock
    ^^^ and makes you ocd over your fueling
  16. Jan 29, 2015 at 11:06 PM
    kigmob
    James
    New Orleans
    My piggyback only controls the 7th injector. I can't add fuel at idle with the 7th. Now if I had the 6 injector upgrade with the FTC or a MAF cal, I could do it. My 7th injector piggyback is an additional injector controller and is designed to control the 7th when under boost. I mean I'm sure I could tell it add fuel at idle but the ECU would just trim the injectors and keep me at whatever AFR it wants. I think as long as it stays around 15-15.5 like it has, I should be ok. Its never for longer than a minute. And even shorter if I start driving and don't sit at idle when I first start up.
  17. Jan 30, 2015 at 2:02 PM
    MadTaco461
    CA
    Kinda stock
    I wouldn't sweat it. It's kinda a pain to tune closed loop. Since it is idle no load I doubt your egt even increase. I'm way worse than you at hot start
