Hot water heater switch/ breaker question
Discussion in 'Garage / Workshop' started by Yodeville, Feb 1, 2020.
  1. Feb 1, 2020 at 3:12 PM
    Yodeville
    Yodeville [OP] 2019 SR with SX Package Central New Jersey
    New Jersey
    2019 Toyota Tacoma SR access cab
    Never Never Modify! Keep it aggravation free!
    I have a fairly new electric hot water heater around 6 months old. This following happened at least 3 times. The breaker had to be reset and the heater will start working again. When resetting the double poll breaker it moves very easily unlike the other breakers and the on/off switch is warm. I took a picture of the switch notice the on lower screw area is discolored. Any ideas? Thanks on advance.IMG_20200201_175942.jpg
  2. Feb 1, 2020 at 3:28 PM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Have you pulled the switch to check the wiring? (after cutting power at the breaker, of course).
    Not an electrician, but my first thought is a loose connection at that contact causing arcing and heat build-up. If that's the issue, it's easily fixed (and a new switch is cheap peace of mind): if not you or an electrician is going to need to chase that line and figure out where the fault is. With that heat build-up you have a fire hazard.
  3. Feb 1, 2020 at 4:15 PM
    Yodeville
    New Jersey
    I will try that. Looks discolored on the bottom wire. Thank you
  4. Feb 1, 2020 at 4:20 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Check the amp/watt rating of the new hot water heater? Is it higher than the original it replaced? Who replaced the water heater, an heating/electrical service person or your brother-in-law?
    Thatbassguy and o0oSHADOWo0o like this.
  5. Feb 1, 2020 at 4:26 PM
    Yodeville
    New Jersey
    Hotwaterheater.com came out. Only happened a few times. I'll try replacing the switch first. Not sure about the amp/watt stuff.
  6. Feb 1, 2020 at 4:27 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    I have a few questions:
    What is the current rating of your breaker?
    What is the current rating of the wall switch?
    What is the current rating of the hot water heater? (with both elements on)
    tcjacado likes this.
  7. Feb 1, 2020 at 4:32 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Is this ac120 volt water heater?
    If this is a 240 volt water heater, you need a 240 volt disconnect.
    In my area, no 120 volt water heaters are connected to a 20 amp switch.
    I think your electrician was you tube trained.
    You need a pro sparky to stop by. I really am worried about this house wiring.
  8. Feb 1, 2020 at 4:34 PM
    koditten
    Kirk
    Central Michigan
    Edit: you said " double pole breaker".
    This is a 240 volt water heater. No way is your wiring up to code.
  9. Feb 1, 2020 at 4:36 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    He could have a two pole switch. It looks like it is rated up to 277v but the image is a little blurry so I can't see the current rating.
    Liquidworld and shakerhood like this.
  10. Feb 1, 2020 at 4:37 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Since when are hot water heaters connected to wall switches? I've never seen that. As far as I've experienced water heaters are direct wired to a breaker in the box. A switch seems redundant.
    If it is actually up to code, that brown area does look like some heat is building up. I'd check the screws for tightness. Personally, I'd replace the switch with a new one and make sure it can handle the power load. Switches are cheap and a new one is cheap insurance to prevent a house fire.
    PzTank, wilcam47 and Yodeville[OP] like this.
  11. Feb 1, 2020 at 4:40 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Some people install a timer to turn the water heater on and off at preset times but I've never seen a switch used to do this either.
    wilcam47 and rnish like this.
  12. Feb 1, 2020 at 4:42 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    A 240v element can be 5500w. That's about 23amps. Id wager that that toggle switc can't handle 23 amps. It's brown because it's going to burn up.
  13. Feb 1, 2020 at 4:45 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Assuming that the switch is only rated for say 20 amps or so, I would be worried about the wire that is used in the circuit. 12 gauge is only good for 20A.
    koditten and tcjacado like this.
  14. Feb 1, 2020 at 6:25 PM
    Yodeville
    New Jersey
    220 and 30 amp switch. Please realized I have minimum knowledge about this. It only kicked off 3 times in 6 months.
  15. Feb 1, 2020 at 6:31 PM
    Yodeville
    New Jersey
    I saw this before in NJ homes. There is a circuit breaker and switch near the hot water heater to turn it off and on. I am going to try the switch first. I think it's a 30 amp. Not sure until I removed it.
  16. Feb 1, 2020 at 6:49 PM
    koditten
    Kirk
    Central Michigan
    Still, it is supposed to kick off if there is a problem. You have had 3 kick offs or warnings that something is amiss.
    Please take precautions and give a call to a pro electrician. Truely, situations like this are what cause houses to catch fire.
    I don't know NJ codes, but in my state, this wiring is completely wrong. It would have never passed inspection.
    If you had a home inspection done before you purchased, I don't know how they missed this.
    Please do not fault yourself. There had to be several sets of eyes that green lit this Tom Fuckery. They should all be held accountable.
    Please put in a call to a pro quickly.
    MuddySquirrel likes this.
  17. Feb 1, 2020 at 6:59 PM
    koditten
    Kirk
    Central Michigan
    In addition, good on you for asking. Good on you for admitting this is not something you know about. Hopefully you can use the bit of info given to help you rectify the situation.
    In addition, electric water heaters are supposed to have a "disconnect" if the water heater is not in sight of the breaker panel.
    You have a switch. Switches are similar to disconnect, but do not completely isolate the circuit from the panel.
    I hope I have not scared you, but there are things that must be done proper, and this wiring is one of those things.
    Again, thanks for the thread. If we can help, we consider the day a win.
  18. Feb 1, 2020 at 8:24 PM
    tcjacado
    tcjacado Well-Known Member
  19. Feb 2, 2020 at 2:15 PM
    ReefSR54X4
    ReefSR54X4 JerzeeBwah
    Jersey
    2016 BB AC SR5
    It sounds like a loose wire, causing high amp draw. Have seen this actually from factory wires internally and faulty installation at wire nut connections..
    Like others said.. either call an electrician or the installer to come back..
    Fun fact: NJ municipal inspector has little knowledge of technical issues, so they only look for proper code of install and paid permit
    shakerhood and tcjacado like this.
  20. Feb 10, 2020 at 12:24 PM
    Yodeville
    New Jersey
    Thank you everyone, the problem is fixed. The 30 amp on/off switch was burned near the bottom screw. I guess that made the breaker go bad. I replaced both the switch and breaker and it's fine now. Thanks again my friends.
    RyanL likes this.
