Hot water heater switch/ breaker question
Discussion in 'Garage / Workshop' started by Yodeville, Feb 1, 2020.
  1. Feb 10, 2020 at 7:19 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Thanks for the current status. It would be shocking and revolting to see your house catch fire due to bad wiring. Hopefully the party that did the work didn't offer too much resistance to fix the problem. Now you can relax, maybe even meditate...ohm. :rolleyes:
    Martyinco and Yodeville[OP] like this.
  2. Feb 10, 2020 at 7:20 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you ask if this wiring was performed to code?
  3. Feb 11, 2020 at 4:56 PM
    Yodeville
    Yodeville [OP] 2019 SR with SX Package Central New Jersey
    New Jersey
    2019 Toyota Tacoma SR access cab
    Never Never Modify! Keep it aggravation free!
    Yes up to code
  4. Feb 11, 2020 at 5:05 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Good to hear, I've seen ac breakers wear out and trip like yours did. First time years ago, I thought I needed a new ac unit. It was a hot friday night, so I tried the stove breaker on a whim. Viola the ac started right up and ran another 10yrs.
    Yodeville[OP] likes this.
  5. Feb 11, 2020 at 5:09 PM
    Liquidworld
    Liquidworld Active Member
    Ken
    Sarasota
    2019 Super White Tacoma DCSB TRD OR 4wd
    The double pole switch is acts as a service disconnect for the water heater if it needs to be serviced, rather than the breaker. For safety of the technician working on the equipment, must be with 5-6 ft of the equipment. Code requirement in some areas. Standard 240v water heaters need at least 10 gauge wire circuit. Glad you figured it out.
  6. Feb 11, 2020 at 5:17 PM
    td812
    td812 Well-Known Member
    Terry
    Southern Indiana
    2018 Tacoma SR
    3" lift in front and 2" in rear. G-FX TR-16 wheels
    I’m confused. If it’s a “hot water heater” does that mean that the waters already hot ? I’m just kidding. I’m not normally a smart ass. I just always giggle when I hear someone call a water heater a hot water heater. Sorry !
    koditten likes this.
