Hot weather starting issues
Discussion in '4 Cylinder' started by Beyote, Jul 22, 2009.
  1. Jul 22, 2009 at 6:49 PM
    Beyote
    Beyote [OP] New Member
    Tacoma
    Hello all.
    My truck has the hardest time starting after it is very hot or very hot outside and under the hood.
    What are my points of interest to check and correct these issues?
    Your ideas are greatly appreciated.
  2. Jul 22, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    Whats the Year, and Engine of your truck?
  3. Jul 22, 2009 at 7:06 PM
    Beyote
    Tacoma
    Thank you!!
    I guess that info is important.
    She is a 2 Wheel drive, 96, 4 banger.
    She is the best motorcycle support truck ever, well,.. as long as she starts.
  4. Jul 22, 2009 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What size 4 cyl.?
  5. May 17, 2010 at 4:09 PM
    adiablo420
    adiablo420 Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    would like some help myself.. having the same issues.. i have a 96 taco 4x4 4cyl.. 2.7 liter... when the engine's hot after starting or hot under the hood, it doesnt want to start. have to let it cooldown..
  6. Aug 10, 2011 at 4:56 PM
    ccs1676
    ccs1676 Member
    Was this issue ever resolved? Looking for the answer to this myself. Just got a 96 Taco 2.4L, reading other places it might be the coolant temp sensor or an air sensor near the filter.
  7. Aug 12, 2011 at 7:08 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    Yes it was... it was the cooling temp sensor. The faulty sensor was telling my computer that my engine was line -10 degrees when started. When the truck warmed up, the sensor was telling the computer it was only 32 degrees. So the idle would run high trying to warm up the engine still when it was already warmed up. Thats also why it wouldn't start. The faulty sensor was making the computer tell the injectors to give more fuel at start. Then it would smell like fuel when it wouldnt start. But Fixed the problem right away bro. Good luck with ya....
  8. Aug 13, 2011 at 5:11 AM
    ccs1676
    ccs1676 Member
    Yeah I have been reading online that a faulty coolant sensor or air sensor can cause this. I have tested the air sensor by simply unplugging it, and the truck starts no problem. I guess replacing it would solve the problem...
