Hot Wheels
Discussion in 'Sports, Hobbies & Interests' started by derekp, Sep 14, 2011.
  1. Sep 3, 2020 at 9:50 AM
    #3461
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    Just came in the mail today. Nice detailed bug but I’m surprised they made the rear deck lid raised up like the picture but doesn’t open.
    RLMoody, Soul Surfer, irayfz6 and 4 others like this.
  2. Sep 3, 2020 at 12:12 PM
    #3462
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    I've been slacking. Got some stuff to post, try to get to it when I get home this weekend...
  3. Sep 3, 2020 at 6:16 PM
    #3463
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Had to open. Way too cool
  4. Sep 3, 2020 at 6:21 PM
    #3464
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    Nice! Think I have that '61 somewhere...
  5. Sep 3, 2020 at 7:42 PM
    #3465
    Toyotacrawler
    Cusseta/Opelika AL
    Older one but a I dig it. @williams63 your buddy needs to get a hold to this one. He'd make it look killer
  6. Sep 3, 2020 at 8:45 PM
    #3466
    Jonas
    Jonas Boogerrrrrr!
    Springfield, OR
    05TRDSport
    What is that?
  7. Sep 4, 2020 at 4:07 AM
    #3467
    williams63
    chili
    nh
    2011 dblcb
    Unfortunately my good friend had a heart attach the other night. He’s doing better today but they won’t allow anybody in to see him.
  8. Sep 4, 2020 at 4:24 AM
    #3468
    Toyotacrawler
    Cusseta/Opelika AL
    Direct from Hot Wheels wiki
    Jaded is a Hot Wheels original design that debuted in the 2002 Hot Wheels line. Designed by Mike Nuttall, Jaded was inspired by Kaiser-Frazer's low-cost "Henry J" 2-door sedan of the early 1950s, which has since become an American classic and the basis for many street-rods and dragsters.
    Oh no. So sorry to hear that. :pray:
  9. Sep 4, 2020 at 12:05 PM
    #3469
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    oh man, that sucks to hear.
    hope he has a speedy recovery
  10. Sep 4, 2020 at 1:47 PM
    #3470
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    Same here.
  11. Sep 5, 2020 at 11:34 AM
    #3471
    Toyotacrawler
    Cusseta/Opelika AL
    HW Wednesday sneak peak
  12. Sep 6, 2020 at 5:16 AM
    #3472
    RLMoody
    Got this one a couple days ago. It has the 67-72 F100s that I really like but the truck isn't that well done. The Gasser Mustang and trailer are neat. I bought it for those. I just posted the 1/24 scale Crane Cams Mustang last week of this car. This is the Gasser version. I turned off the lights and went for a night shot. buzzard 020.jpg buzzard 016.jpg
  13. Sep 7, 2020 at 7:18 AM
    #3473
    Toyotacrawler
    Cusseta/Opelika AL
    Finished up the last two displays yesterday afternoon. I think I'll give it a rest building for now. I'm a little tired of ripping wood and cutting dado's for the time being. A couple notes.
    This will make 2 displays
    Supplies. 1"x8"x 8'-0" poplar for the frame. Sides are 21 1/2" Long, Top and bottom are 41 1/2" Long. Ripped to 1 1/2" wide
    Do this first. Then assemble your frame. Place the frame on the plywood, trace the outside of the frame and cut the back of your display. Assemble the display so that you can make sure the 1 1/2" plywood strips will fit inside. I had to thinly cut away the ends to fit inside frame.
    4x8 sheet 5/32 plywood.
    Rip plywood 9x to make 1 1/2" x 4" Long strips
    Rip again 9x to make 1 1/2" x 4" Long stips
    Tape the (9) 40" long strips together so that they are even on the ends. This is so you can cut dados in the 9 strips at once.
    Do the same for the (9) 20" Long strips.
    You can see my strips here taped together. You will cut dados 5/32" side to interlock the strips.
    Mark the strips 9 times. On the 20" piece spaced every 2"
    On the 40" piece every 4"
    Cut dados in the taped together strips. The depth will be 3/4" deep to interlock the 1 1/2" strips. Very time consuming and dangerous using a table saw. Take your time and take breaks if you need to. Go slow so that the cuts are straight. You have to make two passes on each cut for the thickness of the plywood to fit.
    Once done, sand all the strips if you'd like and assemble.
    Drill 3/16" holes in the corners. Measured 1" both ways from inside the frame. This is used to mount to the wall.
    *I would like to note if you plan on building more than two, buy all of the supplies at once. The first sheet of plywood was perfect, didn't bow or warp after I cut it. The next two sheets I bought warped like you wouldn't believe. It was also milled thinner as well. This was supposedly the exact same plywood (same skew at home depot) but I could definitely tell a difference in thickness. Had I bought my 3 sheets of plywood from the same bundle the first go round I would not have had this problem. Some strips were completely unusable.
    Tools: Bessey 90-Degree Angle Corner Clamp (4 of them)
    Table Saw with fine tooth blade
    Circular Saw
    Speed Square
    Tape Measure
    Chalk Line
    Drill
    Sheetrock anchor (Speed)
    Wood Glue (For frame Corners)
    Bostich Nail Gun (1 1/2" finishing nails) For corners of frame and back of display
    Saw horses
    Safety glasses
    Facemask for sawdust
    BRT64, CementDVL, POOLGUY and 6 others like this.
  14. Sep 8, 2020 at 11:54 AM
    #3474
    williams63
    chili
    nh
    2011 dblcb
    Johnny lightning 1/64 off road bug.
  15. Sep 8, 2020 at 11:56 AM
    #3475
    williams63
    chili
    nh
    2011 dblcb
    I see a lake. Maybe a Hot Wheels boat on the water? With a big rooster tail behind it!
  16. Sep 8, 2020 at 12:18 PM
    #3476
    RLMoody
    I cant believe how VWs there are out there. Diecastmodelswholesale .com has a whole section with nothing but bugs on their website. Im betting Williams63 has most of them.
  17. Sep 9, 2020 at 5:14 AM
    #3477
    Toyotacrawler
    Cusseta/Opelika AL
    Hot Wheels Wednesday Week 37! Yota lakin' it!
    And my wife taking a pic of me getting ready for the shot lol. Side story, my kayak (not pictured) was knocked lose by a ridiculous wake shortly after I took my HW picture lol. The toyota hw truck was washed up the beach haha. Glad my camera wasn't at lake level when that happened
    BRT64, irayfz6, POOLGUY and 7 others like this.
  18. Sep 9, 2020 at 9:07 AM
    #3478
    RLMoody
    Thanks for explaining the story. I was thinking they were just people curious to see what you are doing that showed up. I have to ask why the life preserver on the beach during a photo shoot?
    Keep them coming.
    Toyotacrawler likes this.
  19. Sep 9, 2020 at 9:14 AM
    #3479
    Slow Internet
    Slow Internet 56k Modem FTW!
    Slow...
    1992 Dial Up Modem...
    Wiper Blades
    Tsunamis are sneaky....
  20. Sep 9, 2020 at 9:36 AM
    #3480
    RLMoody
    In Opelika?
