Hot Winch
Discussion in 'Recovery' started by Wixo, Sep 30, 2019.
  1. Sep 30, 2019 at 6:02 AM
    Wixo
    Wixo [OP] Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Morning everybody!
    Is it normal for a winch to get pretty hot after using for a bit? I just reeled it in and it got pretty hot.
  2. Sep 30, 2019 at 6:03 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
  3. Sep 30, 2019 at 6:05 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Yes, especially when under load.
  4. Sep 30, 2019 at 6:07 AM
    Wixo
    Hank
    Tint, LED interior
    Thank you, It didn't have much load, I didnt quite reel it in with the weight of the truck. It got hot and didn't want to try it under load until I knew if that was ok.
  5. Oct 28, 2019 at 9:15 AM
    madcratebuilder
    madcratebuilder Well-Known Member
    PNW
    ZR2 Deepwood Green
    skidz, gears, tune, zeon 12-s
    Lear about the winch duty cycle. Most imports are 20%+/-, that means for every 20 seconds of using it you must let it rest for 80 seconds.
    Wixo[OP] and Gunshot-6A like this.
  6. Oct 28, 2019 at 9:16 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    That ONE time that an OP spells the word "winch" correctly could have been such a good clickbait title :rofl:
    Yeah, they get hot. Toyota says this is normal.
    PNW/TRD Steve likes this.
  7. Oct 28, 2019 at 9:38 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Why does Toyota have anything to say about winches?
    @Wixo, your winch should have a thermal cut off, so it should shutoff automatically to protect itself. That said, the cooler you keep it, the longer it will last. The rule of thumb is 30 seconds on, 30 seconds off. If you think about it, a 30 second pull is a pretty long pull anyway, but letting it cool for another 30 is pretty easy as you're typically making adjustments, stacking rocks or whatever in between your pulls.
    Iirc, my Warn instructions were pretty cagey about showing an actual rated duty cycle, even googling doesn't get you very far... But I think 30 seconds on/off is pretty standard, no matter how hard you're pulling.
    Wixo[OP] and madcratebuilder like this.
  8. Oct 28, 2019 at 9:39 AM
    Gunshot-6A
    Conner
    Everett, WA
    That was more of the TW tag line for "no big deal" they def dont have anything to say on winches.
    Wixo[OP] and jbrandt[QUOTED] like this.
  9. Oct 28, 2019 at 11:00 AM
    Wixo
    Hank
    Tint, LED interior
    Your truck didnt come with a factory winch?
    Gunshot-6A[QUOTED] likes this.
  10. Oct 28, 2019 at 11:15 AM
    Gunshot-6A
    Conner
    Everett, WA
    No, but mine came with that last half liter they forgot in yours :D
    :ohsnap:
    joeyv141 and Wixo[QUOTED][OP] like this.
  11. Oct 28, 2019 at 11:21 AM
    Wixo
    Hank
    Tint, LED interior
    Thats a new one lol
  12. Oct 28, 2019 at 12:43 PM
    jbrandt
    Justin
    $50k for a Pro and you'd think they would...
    Wixo[QUOTED][OP] likes this.
  13. Oct 28, 2019 at 12:49 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    What Winch mfg do you have and have you wired it correctly especially the (-) ground wire . Also are your connections clean of corrosion and dirt ???
    Also most winches have a duty cycle rating and thermal switch . Run the winch using short 20-30 second intervals with 30-45 second power off to cool the motor during hard pulls
    madcratebuilder and Wixo[OP] like this.
  14. Oct 28, 2019 at 2:34 PM
    Wixo
    Hank
    Tint, LED interior
    I got it installed by a shop. The guy (yes I was able to hang out in the back for a part of the install) said he wired it exactly like the instructions said. I trust he did install it correctly, I mean the wiring was pretty damn simple. It wasnt blistering hot, but it was hot. Based off of what everyone else said I think its normal.
    US Marine[QUOTED] likes this.
