"hot wiring" power windows
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jrmntr, Feb 17, 2024.
  1. Feb 18, 2024 at 1:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s fn brilliant!
  2. Feb 18, 2024 at 3:22 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's killer.
    Jrmntr[QUOTED][OP] likes this.
  3. Feb 18, 2024 at 5:30 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Wait, so driving, dome is off, how are the power windows working then?
  4. Feb 18, 2024 at 6:33 PM
    Jrmntr
    Jrmntr [OP] Member
    It was powered from the dome light circuit, not the actual dome light. If the dome light could be turned on the windows had power.
    The circuit itself had a timer, so for ten minutes after ignition off or last door opened it was active.
  5. Feb 18, 2024 at 6:59 PM
    daveeasa
    David
    PNW
    Ahhhh, so the + of dome but chassis ground. Fires relay for window motor power. Hence on for a short duration after ignition but guaranteed to time out at some point? Then once a door opens, back on?
    This seems doable with a plug and play kit in the driver kick panel and a tie to the A pillar T and an add-a-fuse. Might be a fun project someday.
  6. Feb 19, 2024 at 11:48 AM
    Jrmntr
    Jrmntr [OP] Member
    Yeah that's exactly how it worked! I've been missing it ever since I sold that truck. I don't understand why the windows need to stop working as soon as a door opens.
    It would be awesome if you were able to help! Do you think it would be as simple as providing a 12v signal to whichever wire would control them?
  7. Feb 19, 2024 at 11:59 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Curious how Toyota wires rear window on 4Runner as it works without key in ignition, wonder if any of that may help your pursuit.. just a thought
  8. Feb 19, 2024 at 12:00 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Pretty sure the timer is in the cpu and is on the ground side. This is why you can still turn on the inside lights at any time whether the doors are open or closed. The dome switch just controls whether the path to ground goes straight to the chassis or through the timer(cpu). It's likely you need a completed ground path rather than 12v. Also, I think the window timer is separate from the dome timer since they have different delay periods.
  9. Feb 19, 2024 at 12:11 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    So you have to drive with the doors unlocked to use the windows?
  10. Feb 19, 2024 at 12:59 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not at all. This is for when the key is not On. Just parked.
    Jrmntr[OP] likes this.
  11. Feb 19, 2024 at 1:16 PM
    daveeasa
    David
    PNW
    I assumed the dome times out at some point? But maybe that’s done with the ground floating even when switched on? Rather than disconnecting power.
    if it’s all ECU controlled grounds then there probably isn’t a good reason to avoid an aftermarket timer to latch window power for XX minutes after they time out on their own.
    tonered and Jrmntr[OP] like this.
  12. Feb 19, 2024 at 1:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yeah. You get 20min with the dome lights, I think. Still 20min after turning off would be nice?
    daveeasa[QUOTED] likes this.
  13. Feb 19, 2024 at 2:00 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Just pointing out tying it to door lock status isn’t a great idea.
    I think though I could be wrong that installing a switch to connect all the window relay coils to ground wouldn’t create a parasitic drain since current would only flow when a window switch was activated.
  14. Feb 19, 2024 at 2:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have no idea and would let that up to the folks who know more about the stuff. I'm just a guy wishing for a nice-to-have thing.
  15. Feb 19, 2024 at 2:02 PM
    #35
    bagleboy
    Scott
    Norcal, Santa Rosa
    I think if you want it all you’ll want it anytime. Like camping & such.
  16. Feb 19, 2024 at 2:34 PM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Anytime the doors are unlocked is the dream.
  17. Feb 19, 2024 at 2:51 PM
    #37
    T4R_hereforbearings
    WA
    08 4Runner
    What about method of constant power like people that have wired dash cam to stay on when truck is parked? Applicable?
  18. Feb 19, 2024 at 6:00 PM
    #38
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Upgrade to crankolators and call it a day
  19. Feb 19, 2024 at 6:25 PM
    #39
    bagleboy
    Scott
    Norcal, Santa Rosa
    :deadhorse:
  20. Feb 19, 2024 at 10:38 PM
    #40
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    A lot of people missed my post #2. The windows already have constant power. The windows stop working when the LIN tells them to stop working. Please read post # 2 and get the schematic in Post #18.
    @daveeasa needs to read these posts as well.
