Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Dec 13, 2013 at 9:10 AM
    #3021
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Red, i think you might be a little high on that correction factor. where'd you pull that from?
  2. Dec 13, 2013 at 9:13 AM
    #3022
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Guess im not getting 14mpg? Lol
  3. Dec 13, 2013 at 9:15 AM
    #3023
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    depends on your actual tire size. my 35s actually measure as a spot on 35, and my correction factor is in the 12.5% range.
  4. Dec 13, 2013 at 9:22 AM
    #3024
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    The 35 gives you a 14.6% larger circumference, but that equates to a 12.7% drop on your revolutions per mile.
  5. Dec 13, 2013 at 9:25 AM
    #3025
    Large
    Large Red
    I guess the best bet would be to actually measure the tire height ?
  6. Dec 13, 2013 at 9:29 AM
    #3026
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    bingo, gotta use the the factor asociated with distance, not size.
    that's the best way to do it. tire size calculator will get you a good ballpark, but you need to measure to get the true value, since sizes vary so much
  7. Dec 13, 2013 at 9:34 AM
    #3027
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Think we measured last time, came out to 34
  8. Dec 13, 2013 at 9:35 AM
    #3028
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Which would be the circumference, the actual distance that is being traveled per rev. Correct me if I'm wrong, but If you're trying to manipulate the mileage driven (distance); would you not want to use the percentage associated with the increase in distance. The revolutions aren't a distance measurement, although they happen to be indirectly based off of distance.
    My math a while back led me to use the circumference difference... Of course I'm no mathemetician
  9. Dec 13, 2013 at 9:38 AM
    #3029
    Large
    Large Red
    It would make more sense (to me anyway) to use the circumference of the new tire and get a measurement of the old tire and get the difference in % to be more accuraate than diameter no?
  10. Dec 13, 2013 at 9:39 AM
    #3030
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Sounds like yall know what yall are talking about to me
  11. Dec 13, 2013 at 9:43 AM
    #3031
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Clicked on thread to see the bad ass 25 mpg toy on 40's.
    Are you guys saying you don't need to correct the miles driven after regearing? You're definitely need to correct after regear, your tranny only knows it's own rpm, and your miles are based on stock gears at tranny rpms, if you change your gears, your tranny still thinks you have stock gears. You need to correct for gear ratio and tire size.
  12. Dec 13, 2013 at 9:45 AM
    #3032
    Large
    Large Red
    fixed.
  13. Dec 13, 2013 at 9:50 AM
    #3033
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    revs per mile and circumfrence are directly asociated, and therfore use the same factor. while you can derive the factor from diameter, it takes more steps, and isn't directly equal. remember pi*r^2 from back in highschool ;)
    for manual transmissions, you are correct, you need to correct for gearing changes. that is because the computer get's it's infor from the transmission itself. with automatics on the other hand, the computer get's that infor from the wheelspeed swensors (downstream of the diffs), and therfore, will only be thrown off by a tire size change. you could regear your tranny, transfer case, and diffs, and still have an acurate dash reading on stock tires.
  14. Dec 13, 2013 at 9:51 AM
    #3034
    Nickel
    Diego
    2013 T/X TRD
    Lol, that works too.
    I didn't realize the speed sensors were after the differential. Thanks
  15. Dec 13, 2013 at 10:17 AM
    #3035
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    Well maybe I miss spoke with that. It depends which direction you're going with the factor though... Talking about Circumference you're going from a smaller to larger number. You will get a higher percentage difference (14.6 increase). In reference to revs/mile you're going from a larger number to a smaller number. The percentage will be smaller (12.7 decrease) and it will be subtracting from the original versus adding to.
    I figure you'd want to keep the proper percentage changes with the same units... 14.6 distance increase if you're manipulating the distance driven. I don't see why you'd use the 12.7% rev decrease to increase the distance value.
  16. Dec 13, 2013 at 10:19 AM
    #3036
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    this thread is way too fucking smart today.
  17. Dec 13, 2013 at 10:22 AM
    #3037
    richardbui23
    Richard
    Arlington Texas
    Stacy
    :bananadead:
  18. Dec 13, 2013 at 10:25 AM
    #3038
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Got back from lunch to find the outlets in my office are dead. I guess it's time to go home.
  19. Dec 13, 2013 at 10:31 AM
    #3039
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    :spy:
    :D
    Next time I see you I'll bring a few ounces of that flocculant. The possibilities are endless.
    Those are the best pages.
    :spy::spy::spy:
    :spy::spy::spy:
    I'll work on this during my lunch break.
  20. Dec 13, 2013 at 10:33 AM
    #3040
    richardbui23
    Richard
    Arlington Texas
    Stacy
