Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Jun 13, 2014 at 12:43 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    that was the goal when i built mine ;)
  2. Jun 13, 2014 at 12:55 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    eha6e6up_f7f204628581aff26f1f9a3936e01d8ccc474e59.jpgbune4ejy_385c85ab2afde624425e4c5e497b799001fecb07.jpg
    My buddy is building this trailer right now.
  3. Jun 13, 2014 at 1:10 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Let me have have one or two..
  4. Jun 13, 2014 at 1:47 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    :spy:
    :notsure: I break 'em... not fix 'em!
    For the axel I went with a 3500#, 65" hub face to hub face. The guy at trailerpartsdepot.com wouldn't know customer service if it jumped the fuck up and kicked him in the face. Unfortunately they were the only ones I could find who had a 3500# axel @ 65" with the superlub axel.
    Found here:
    http://trailerpartsdepot.com/itemdesc.asp?ic=49929&eq=&Tp=
    For the Hub and Brake Assembly I went with etrailers.com. Now these folks are the schnizzle when it come to customer service. Very AWESOME experience with them on the phone, and therefore they will get the rest of my business for trailer components if I happen to need more.
    I went with the Dexter brake hub with a 10" 6x5.5 bolt pattern so they will be an identical to the Tacoma. Going inside them will be Dexter Nev-R-Adjust 10" drum brakes.
    http://www.etrailer.com/Trailer-Brakes/Dexter/23-469.html
    I also went with the E-Z lube Dexter hub.
    http://www.etrailer.com/Trailer-Hubs-and-Drums/Dexter/84656UC3-EZ.html
    For the springs I went with these...
    http://www.summitracing.com/parts/exp-51413
    And I ordered heavy duty off-road fenders from sierra4x4trailers.com
    As you can see this is eerily similar to Jason's (jberry) setup. I have been chatting a bunch with him to match my trailers off-road performance with his. This is why I'm setting up my suspension exactly the same as his. My trailer will be similar to his, but with more cowbell to set it apart. I have several additional tricks I'm going to try and pull off.....;)
  5. Jun 13, 2014 at 1:51 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Very Nice start! don't forget the u-bolt kit for the springs ;)
    whether it's a square or round tube axle, make sure to get the proper bolts and plate to mount hte bolts facing up. no need to kill clearance.
  6. Jun 13, 2014 at 1:54 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    What were they filled with?
    How big of a light bar can I fit on a 3" lift with blinker fluids?
  7. Jun 13, 2014 at 1:56 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    :humble:
    Already planned for...
  8. Jun 13, 2014 at 2:00 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    My trailer will be heavier than Jason's because of the additional creature comforts I plan. I will also have additional storage built into mine. I figured if I was going to make the financial commitment I might as well go all in.
    I know Jason had to revalve his shocks and remove a leaf from his setup. So I think I should be about spot-on when I'm done. Either way I'm going to wait to custom order the shocks until I know what kind of weight I'm looking at. My questimation right now is that I will be in the 1400# range empty.
  9. Jun 13, 2014 at 2:15 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    nice, mine's about 1200 empty right now. already finished my plans for the rebuild though, which will alter that number a bit. just have to figure out spring rate and valving for the coilovers.
  10. Jun 13, 2014 at 2:20 PM
    BulletToothTony
    BulletToothTony [OP] You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
  11. Jun 13, 2014 at 2:51 PM
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    Rich sees cool shit.
    Rich adds shit to Taco.
  12. Jun 13, 2014 at 2:59 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    Haha
  13. Jun 13, 2014 at 3:01 PM
    jbmccul
    Red emblems, bronze wheels, assorted crap
  14. Jun 13, 2014 at 3:05 PM
    BulletToothTony
    ^ don't forget elocker installed but never hooked up ;)
  15. Jun 13, 2014 at 3:11 PM
    jbmccul
    How could I forget about that :facepalm:
  16. Jun 13, 2014 at 3:25 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
  17. Jun 13, 2014 at 3:36 PM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    You forgot the red valve stem caps...:puke:
  18. Jun 13, 2014 at 3:52 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    I didn't have that..
  19. Jun 13, 2014 at 3:56 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    Don't lie!! You know you thought they were bonertastic
  20. Jun 13, 2014 at 4:16 PM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    I would say that's too much red but....u9uzybuq_58cc205897f956cd30db01223c3e865f224ceac8.jpg
