Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Jul 7, 2014 at 8:37 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
  2. Jul 7, 2014 at 8:42 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    :rofl:work must be slow for you mike!
  3. Jul 7, 2014 at 8:43 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  4. Jul 7, 2014 at 8:58 AM
    Delmarva
    Tucson, AZ
    indeed... slow monday after 4 days off... hard to get back in the groove
  5. Jul 7, 2014 at 9:13 AM
    ThirdCoast
    ThirdCoast Well-Known Member
    Houston
    2011 DC TRD TX
    Do any of yall have hood mount lights?
  6. Jul 7, 2014 at 9:16 AM
    sarsabious
    sarsabious Now I understand everyone's shit's emotional.....
    Dwayne Elizondo Mountain Dew Herbert Camacho
    Republic of Texas
    RIP Barnibus Stinson
    General swagger and pizzazz.
    This is another clear cut case of bitch had it coming. People dumb enough to A) buy a galant and B) then drive it on the soft sand deserve to be left stuck and figure out how get it out of the mess on their own. I am a huge advocate of severely punishing stupid people.
  7. Jul 7, 2014 at 9:20 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    They would just start off slowly, and then when they would lose speed, they would then give it too much gas. I stayed and watched for about 10 minutes. awesome entertainment.
    Someone was brave/stupid enough to drive a Charger out there. Almost got stuck getting past that part. I wonder if he ever made it back.
  8. Jul 7, 2014 at 9:21 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  9. Jul 7, 2014 at 9:30 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Because they want to get as close to the water as they can.
    You would think that seeing the 2WD full size trucks getting stuck would be a hint to leave your car on the road and walk to the water.
    However, some cars can deal with mudholes.
    https://www.youtube.com/watch?v=MyRRJyEEjac
  10. Jul 7, 2014 at 9:59 AM
    sarsabious
    Republic of Texas
    I can understand a Chevy LS swap, but this makes not a bit of sense. But your car, your loot, and I think it'd be interesting to see completed.
  11. Jul 7, 2014 at 10:06 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Miata = RWD
  12. Jul 7, 2014 at 10:08 AM
    sarsabious
    Republic of Texas
    Miatas are always RWD. No conversion necessary.
    http://en.m.wikipedia.org/wiki/Mazda_MX-5
  13. Jul 7, 2014 at 10:38 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Just a bit worse then the FWD cars :D
  14. Jul 7, 2014 at 10:41 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Ahhh, thought your comment was refering to the Miata as a FWD car,,, so NVM. But, if you can shoehorn a 5.0 crate engine into the bay, I certainly would think a 2.0 TDI would fit.
  15. Jul 7, 2014 at 10:52 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    If you put your truck in Broja mode, you may have a chance.
    Most of those cars that made it through there were going about 10mph+. Although they had no control, and almost slid into other stuck vehicles. Had a guy in a Suburban almost slide into the side of me as I was driving through that area.
    Just get a buddy to come to the beach with you and find out what you can and can't do.
  16. Jul 7, 2014 at 10:53 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The car will be rear wheel drive.
    ACME adapters makes a kit to convert the TDI into a longitudinal setup.
    I'll use a Toyota W series transmission out of a late 80's early 90's pickup as the gear ratios are almost identical to that of the TDI transmission.
    The curb weight of the miata is literally a ton less than that of the VW Golf I used to have, and that Golf was no slouch. (After working it)
    So I'll have a 2000lb, rear wheel drive, and 180hp/300ftlb little rocket that will get around 50mpg and run somewhere around an 11 in the quarter. (guessing at the quarter times as my pig of a golf ran low 14's)
    Sounds like fun to me.
  17. Jul 7, 2014 at 10:53 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    IMO, better traction from the weight over the front wheels and being able to angle the wheels some as necessary. Trucky is light over the rear wheels. But sand is a totally different animal. Truck may be better if its soft and the car starts to drag. Truck tires are generally wider, so that helps the trucky.
    End of the day, just don't drive into the dark water puddle!!!
  18. Jul 7, 2014 at 10:53 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    AND BECAUSE DIESEL!!!!!!!
  19. Jul 7, 2014 at 10:54 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Have a good welder/fabricator on retainer :D:D
    JK, Nathan posted that someone makes a kit....
  20. Jul 7, 2014 at 10:58 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    $600 for the kit that works with the Toyota transmissions
