Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Nov 19, 2013 at 6:40 AM
    #401
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    genius
  2. Nov 19, 2013 at 6:42 AM
    #402
    Large
    Large Red
    I should say, that is the way it was on my 11. I think I want to do a different route for the 12, I am going to run a 2 ga from the battery to behind the rear seat and set a fuse block and put another fuse block under the hood.
  3. Nov 19, 2013 at 6:46 AM
    #403
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Where are y'all grounding your amps? The next time I get cash I'm Gonna dynamat my floor and doors. And doing so I'm Have to remove my ground to remove the carpet.
  4. Nov 19, 2013 at 6:46 AM
    #404
    Large
    Large Red
    If it's done right I don't worry too much about it.
  5. Nov 19, 2013 at 6:48 AM
    #405
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you already have one fuse box inside the cab. no different adding another.
    grounded it right behind the rear seats where it's mounted. onoly took about a foot of cable.
  6. Nov 19, 2013 at 6:50 AM
    #406
    TexasPreRunner
    Anthony
    2011 PreRunner
    Ah ok so you used a seat bolt
  7. Nov 19, 2013 at 6:53 AM
    #407
    Large
    Large Red
    No carpet behind the rear seats :confused:
  8. Nov 19, 2013 at 7:03 AM
    #408
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i can't remember. either a seat bolt, or just a bolt that holds the body together.
  9. Nov 19, 2013 at 7:07 AM
    #409
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    Haven't you seen Joe's truck?
  10. Nov 19, 2013 at 7:10 AM
    #410
    TexasPreRunner
    Anthony
    2011 PreRunner
    Il try a bolt out when it comes to it. I used a self tapper on it now but I don't feel like it's going to hold up
  11. Nov 19, 2013 at 7:12 AM
    #411
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    also remember to knock off the paint wherever you are grounding. a structurally sound connection does no good if it's govered in paint.
    i don't like them, but this is one case where a riv-nut could be usefull.
  12. Nov 19, 2013 at 7:13 AM
    #412
    richardbui23
    Richard
    Arlington Texas
    Stacy
    yall are busy in here this mornin lol
  13. Nov 19, 2013 at 7:13 AM
    #413
    jbmccul
    Bulhas
  14. Nov 19, 2013 at 7:14 AM
    #414
    richardbui23
    Richard
    Arlington Texas
    Stacy
    :eek:
  15. Nov 19, 2013 at 7:15 AM
    #415
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    pull your carpet before you weld ;)
  16. Nov 19, 2013 at 7:15 AM
    #416
    TexasPreRunner
    Anthony
    2011 PreRunner
    Do you know if I can bridge 8 guage amp wire to a splitter block to another amp or do I need to move to like 0 guage. My brother in law offered me amp so I can do my door speakers.
  17. Nov 19, 2013 at 7:17 AM
    #417
    jbmccul
    Yup.
    Anything in your truck will burn if you get it hot enough. I once watched a Suburban melt down to the frame while burning off the paint on the cars next to it
  18. Nov 19, 2013 at 7:18 AM
    #418
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    how big is your amp? 8 guage is pretty small. i think i'm running 2 guage to my single 1000w amp. it measures closer to 3 guage though.....
  19. Nov 19, 2013 at 7:19 AM
    #419
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i had a small fire under my truck when i was welding on my sliders. the rear diff breather hose was about an inch off of the inside of the frame rail and still caught fire from the heat from the welder on the other side of the frame.
  20. Nov 19, 2013 at 7:20 AM
    #420
    TexasPreRunner
    Anthony
    2011 PreRunner
    I currently only have a 500w 175 rms kenwood for my 10 inch sub. So the 8 was the largest I could run to the terminal on the amp.
