Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Nov 19, 2013 at 7:21 AM
    #421
    jbmccul
    jbmccul Well-Known Member
    2021 GMC Sierra AT4, 2019 Audi A5, 2017 Audi Q5
    I had a brake line (I think) pretty close to where we were gonna have to weld. Unhooked it from the bracket, pulled it out of the way and then went to town
  2. Nov 19, 2013 at 7:25 AM
    #422
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i was only welding and inch at a time, then moving to another leg. with 8 legs, by the time i got back to the first leg for the next round, i could bare skin touch the first weld. it was just a matter of an easier than normal to ignite material being a little too close.
  3. Nov 19, 2013 at 7:25 AM
    #423
    jbmccul
    I didn't weld them, I watched. I let my friends dad do the welding. He had some pretty sweet toys in his shop
  4. Nov 19, 2013 at 7:34 AM
    #424
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it keeps up. i've actually never gotten a warning light on it, and i've done some really long welds on my skid plates, and pushed it pretty hard with the front and rear bumpers.
  5. Nov 19, 2013 at 7:40 AM
    #425
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Totally depends on the total amps you may need going through that 8ga wire. Several on-line charts that document ga vs. distance vs. amps. Personally I would just pull a 0-2ga to a dist-block, then run the 8s from there. But I tend to over-engineer anything I don't want to re-do.
    On the Tacoma I have a 0ga from the battery to a dist-block behind the rear seat, then an 8 to the amp. Last truck I had the dist block under the drivers seat with one amp under the passenger seat and the other amp under the rear seat.
  6. Nov 19, 2013 at 7:45 AM
    #426
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i forget what it's rated for in the manual, but i've cut a crosssection of a 1/4'' to 3/16'' plate steel joint and it had proper penetration. same joint did well in the destructive testing machine. Haven't tried it yet, but i would think that i could get the job done with a double pass on 1/4'' to 1/4''
  7. Nov 19, 2013 at 7:51 AM
    #427
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    Thanks, That sounds like what I need to do. I'd rather over engineer
  8. Nov 19, 2013 at 7:52 AM
    #428
    jbmccul
    There's too much technical chatter in the BS thread!
  9. Nov 19, 2013 at 7:54 AM
    #429
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ...only so much we can do without Dennis...
  10. Nov 19, 2013 at 7:54 AM
    #430
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    different applications.
    and now that you mention that, i've welded my shackle points onto the rear bumper. that's 1'' to 3/16''. did a tripple pass on that, and they are rock solid. i really don't need a welder for what i do that can burn half inch to half inch all day long.
    and yeah, thicker steel is always easier. i've started to take pride in my ability to do the thin stuff now though. i can get a decent bead on steel thinner than the sheet steel on our truck bodies. built my old air filter box out of some crazy thin guaged sheet steel. that took soem serious focus hand control.
  11. Nov 19, 2013 at 7:55 AM
    #431
    jbmccul
    He get the hammer?
  12. Nov 19, 2013 at 8:03 AM
    #432
    TexasPreRunner
    Anthony
    2011 PreRunner
    Ya I don't think it's permanent though.
  13. Nov 19, 2013 at 8:03 AM
    #433
    jbmccul
  14. Nov 19, 2013 at 8:04 AM
    #434
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
  15. Nov 19, 2013 at 8:04 AM
    #435
    richardbui23
    Richard
    Arlington Texas
    Stacy
    bored out of his mind lol.
  16. Nov 19, 2013 at 8:06 AM
    #436
    TexasPreRunner
    Anthony
    2011 PreRunner
    Your a frat guy right? If so does it consume your life? my roommate just picked for president he's so damn busy we rarely see him.
  17. Nov 19, 2013 at 8:09 AM
    #437
    jbmccul
    Not really. I'm in a business fraternity. Not nearly as much stupid going on
  18. Nov 19, 2013 at 8:10 AM
    #438
    TexasPreRunner
    Anthony
    2011 PreRunner
    Sounds like one that may actual be useful
  19. Nov 19, 2013 at 8:11 AM
    #439
    jbmccul
    :brianr:
    It has been so far. But as you can see from some of my posts, we still party hard
  20. Nov 19, 2013 at 8:12 AM
    #440
    Large
    Large Red
    "What do you say Jackington, shall we escort the local bimbo to the latest box social"
    "Sounds devlish Mark Anthony"
