Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Feb 3, 2014 at 7:21 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    one of the uav launchers I use (for the 40 pound fixed wing) uses a warn winch and amsteel blue to compress gas springs...
    works like a charm... don't know if its got an indrum brake however
  2. Feb 3, 2014 at 7:26 AM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    Browsing the TDPS website for vehicle inspections. Particularly interested in the exhaust portion of the inspection. This is what I found….
    For trucks with an installed canopy or camper, for the sake of the inspection, it is considered part of the passenger compartment. Without a topper, the passenger compartment ends at the end of the cab. Wheww. My exhaust chop is indeed legal.
    DPS states a vehicle will fail inspection if:
    "The tailpipe fails to discharge exhaust from the rear or sides or top of the passenger compartment of the vehicle."
  3. Feb 3, 2014 at 7:28 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Pft dumping the exhaust is so played out I'm gonna do fender exits!
  4. Feb 3, 2014 at 7:28 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    The brake isn't used for pulling line in, it's used when letting line out under power. If you're lowering yourself down an incline the brake will come into play.
  5. Feb 3, 2014 at 7:29 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    This would be a perfect opportunity for you to reroute your exhaust into a stack...
  6. Feb 3, 2014 at 7:29 AM
    Delmarva
    Tucson, AZ
    ahh gotcha thanks...
    ya we compress the springs with the winch and then release the compression instantaneously
  7. Feb 3, 2014 at 7:29 AM
    Delmarva
    Tucson, AZ
    indeed... i wouldn't' laugh at you at all
  8. Feb 3, 2014 at 7:30 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Virginia law states the same. i had to dig like crazy to find it, but it is indeed legal as long as you get past the rear or side of the cab. no need to get out from under the bed without a cap :)
    i actually had to print it out from the official Gov. site and show the Virginia inspectors, because they didn't believe me. wanted to fail me until i pulled out the documentation :facepalm:
    embarrassed a couple of Mexicants that day :p
  9. Feb 3, 2014 at 7:31 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i really want to go through the bedside to get it a little higher. it's prettyl low on the priority list though, so i don't see it happening too soon.
  10. Feb 3, 2014 at 7:32 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    :laugh:
  11. Feb 3, 2014 at 7:33 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    I thought about it when I was doing my exhaust. :anonymous:
  12. Feb 3, 2014 at 7:35 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    most people miss that one ;)
  13. Feb 3, 2014 at 7:36 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    :cheers:
  14. Feb 3, 2014 at 7:46 AM
    Delmarva
    Tucson, AZ
  15. Feb 3, 2014 at 7:48 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  16. Feb 3, 2014 at 7:50 AM
    mipawlus
    mipawlus #332 Veteran Overland, #159 TTC, #69 in your heart
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Rust and dents and squeaks
    Woot! Made just shy of 2k$! I'll take that and run with it!
  17. Feb 3, 2014 at 7:50 AM
    mipawlus
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Win.
  18. Feb 3, 2014 at 7:50 AM
    Delmarva
    Tucson, AZ
    :woot:
  19. Feb 3, 2014 at 7:54 AM
    Jetlander
    Jonathan (aka MOAB)
    Depends on the day.
    For those who are electrical savvy…
    I'm trying to wire up my license plate lights.
    I have good continuity in the wires to to the LED's (tested with a 9v battery)
    And I also have power coming from the cannon plug wires for the license plate light.
    However, I can't get the lights to come on when I hook the two together. I have tried all the different possibilities for polarity… Still nothing.
    Any suggestions?
  20. Feb 3, 2014 at 7:54 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    Walk away and phone a friend
