Houston area (along with DB's not from Houston) BS thread
Discussion in 'Texas' started by BulletToothTony, Nov 15, 2013.
  1. Feb 3, 2014 at 12:12 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    strange...
  2. Feb 3, 2014 at 12:14 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
    What cigars you smoke today?
  3. Feb 3, 2014 at 12:16 PM
    Large
    Large Red
    I'd fill the void with extra strands of wire, use the correct crimping tool like a green lee 1 shot, the wire will break before the crimps / lug gives out.
  4. Feb 3, 2014 at 12:23 PM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    At least it's not to springish
  5. Feb 3, 2014 at 12:29 PM
    Delmarva
    Tucson, AZ
    Truth
  6. Feb 3, 2014 at 12:34 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i was talking about better current flow with solder, not better physical strength. with solder, you'll get higher surface area contact with the crimp.
  7. Feb 3, 2014 at 12:49 PM
    Large
    Large Red
    I'll leave it alone but I'll throw my 2 cents. I've seen solder fail too many times & especially with vibrating equipment (a running engine), I've yet to see a properly crimped lug fail, but on my terminations I always go overkill with a shot of solder a good crimp, hear shrink (sometimes cold shrink) and a jacket if the terminals are close.
  8. Feb 3, 2014 at 12:54 PM
    Large
    Large Red
    I am gonna test your solder vs a regular crimp of current flow though, now that you've sparked my interest.
  9. Feb 3, 2014 at 12:56 PM
    Delmarva
    Tucson, AZ
    I fully expect an engineering report at the conclusion of your testing.
  10. Feb 3, 2014 at 12:59 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    So here's the next question. Should I sleeve the cables?
  11. Feb 3, 2014 at 1:03 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    I always sleeve connections
  12. Feb 3, 2014 at 1:05 PM
    Large
    Large Red
    :laugh: well I've put an amp probe on a 600 amp motor with only lug connections (well over 100 times) & no telling how many 400 amp and lower current motors, all we use are crimped lugs with no solder. They vibrate to hell when they are running
    If they could move & contact anything I would, even if it's just plastic conduit.
  13. Feb 3, 2014 at 1:06 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The connections will be crimped and heat shrinked. I was just thinking that the green insulation is going to stick out like a sore thumb in the engine bay.
  14. Feb 3, 2014 at 1:08 PM
    Jetlander
    Jetlander Just trying to measure up...
    Jonathan (aka MOAB)
    Depends on the day.
    2010 Tacoma DCSB 4x4 SR5
    TKO Wheel w/ 35" BFG KM2, Volant CAI, Safari Snorkel, 3" lift, All-Pro Full Skid Underarmor, Chopped/Re-Routed FlowMaster Exhaust, CBI Moab 2.0 Front Bumper, DerpWerx High Clearance Rear Bumper, Rear Tire Swing Out, BAMF Sliders w/Kickouts, King Resi w/700# Coilovers on front, Total Chaos UCA's, King Long Travel with Resi's, Shock Hoops and King 2.5 Bump Stops, OME Dakar Leaf Springs mounted on All-Pro Shackle Flip w/ U-Bolt Flip, extended SS Brake Lines, DerpWerx Bedrack, 10# C02 Tank, Black Badges, Dual Optima Red Top's, Blue Sea 12 Fuse Block on custom Block mount, SuperWinch 9.5iSR Talon w/synthetic line, Prolink Thimble, 20" Rigid Dual Row LED Light Bar, Rigid Dually Floods, OTRATTW Switches, Cab Mount Chop, Cobra CB w/ 4' Firestik, Center Counsel Glock 23 mount (with plenty o' ammo!), Weathertechs, and plenty more mods to come!
    It'll look pretty.
  15. Feb 3, 2014 at 1:08 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  16. Feb 3, 2014 at 1:13 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    we're on the same page. i wasn't saying only solder. i may have worded it poorly the first time. i meant fill the voids with solder, and then crimp it. i'm not a fan of straight solder either.
    :popcorn:
    from a mathematical standpoint, the better contact patch will yeild better flow with lower temps. the potential to keep that from happening is that you move from a single connection, to essentially two different connections, with the addition of a new material. it may very well come down to solder quality (if there is a measurable difference)
  17. Feb 3, 2014 at 1:17 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    here's what it'll look like
  18. Feb 3, 2014 at 1:18 PM
    TexasPreRunner
    Anthony
    2011 PreRunner
    I thought you ment heat shrink. Sleeves would look cool
  19. Feb 3, 2014 at 1:19 PM
    PcBuilder14
    Brent
    Nor Cal
    It's what I plan to do for all of my accessory wiring. I have 100 feet of it right now...
  20. Feb 3, 2014 at 1:23 PM
    Large
    Large Red
    With aluminum (conductors) it might be but copper (what I use 95% of the time) current won't fluctuate as much with ambient temps changing, only with the load you put on the wire (not saying temperature won't have a say so in the current draw fluctuation [5% if that] but it is not as noticeable with a copper conductor).
