Houston BS Thread
Discussion in 'Texas' started by wrxRome, Apr 12, 2012.
Thread Status:
Not open for further replies.
  1. Oct 9, 2013 at 6:30 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Indeed, if the crooked bed bothers you...
  2. Oct 9, 2013 at 6:33 AM
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    It's enough to bother me if it makes me look like I'm dog/crab walking.
  3. Oct 9, 2013 at 6:33 AM
    Delmarva
    Tucson, AZ
  4. Oct 9, 2013 at 6:38 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Yes, but I think its usually cause by the rear being off alignment correct?
  5. Oct 9, 2013 at 6:39 AM
    Delmarva
    Tucson, AZ
    Too much truck talk in the BS thread...
    :laugh:
  6. Oct 9, 2013 at 6:41 AM
    Biscuits
    Yeah.
    Possibly. Probably. I just had my alignment redone Monday. As soon as Adam told me about it and I looked the truck over, I called the alignment shop to make an appointment to fix their original craptastic job. So does it still look like I'm crab walking? I don't know. It wasn't something major to begin with but knowing that it was there bothers me enough to address all possibilities to eliminate the problem.
    Don't know how the rear would be out of alignment though.
  7. Oct 9, 2013 at 6:42 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    or if the axles are aligned. my xB has a slight dog walk because i think the back axle is shifted over a bit (drifting jumping wrecking you know that illest life). goodmorning everyone the ladies were nice i also liked her smile :anonymous: go with a low profile plate bumper dennis. if not then buy a tube and add a battering ram in front
  8. Oct 9, 2013 at 6:45 AM
    Biscuits
    I've seen some threads and what happened to you that's caused the misalignment, but that will probably be the last thing I check. Why? It's the most difficult task and I make sure everything was torqued down before the leafs were installed.
  9. Oct 9, 2013 at 6:46 AM
    wrxRome
    wrxRome [OP] Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    :pccoffee: I have been summoned
  10. Oct 9, 2013 at 6:47 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    There's no aligning the rear if leaf sprung. links, sure, but not us. it is however possible that your axle is out of alignment for any number of reasons. could be a bent or broken centering pin, spring hanger tolerance, tweaked frame, uneven spring height from side to side, etc.....
    if your axle is off, that causes what's called a thrust angle. it's the angle difference between a line perpendicular to your rear axle, and the centerline of the vehicle. all vehicles have some amount of thrust angle jsut because they aren't perfect. next time you get an alignment, have them print out the sheet at the end, and it'll give you a thrust angle. that's usually the number you look at after a wreck to see if the frame has been damaged. a large enough thrust angle can give you the crab walk look.
  11. Oct 9, 2013 at 6:48 AM
    wrxRome
    Brandon
    No adjustments in the rear. However. If you have the wrong side leaf in then it will cause a shifted axle. Ie the driver side leaf pack is taller than passenger so it will push it back a hair.
  12. Oct 9, 2013 at 6:48 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    fuck that im not trying to be apart of that illest life im gonna leave that to the kids
    i want volcoms plate/tube hybrid. i origanally wanted susans but i no want to copes [​IMG].
  13. Oct 9, 2013 at 6:49 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i swapped my center pins out for grade 8 bolts.
  14. Oct 9, 2013 at 6:51 AM
    Large
    Large Red
    I was contemplating doing this, what size you use? 1/4" or 3/8" I would guess.. maybe 5/16"
  15. Oct 9, 2013 at 6:52 AM
    wrxRome
    Brandon
    That and didn't have time to fuck with it lol
  16. Oct 9, 2013 at 6:53 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    very true but the point of bringing him up was his bumper. in that thread they mentioned that the bumper had almost no damage after he landed on it. i think it was like pushed back and slightly bent or some shit like that
  17. Oct 9, 2013 at 6:54 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i really can't remember. it was years ago. i need to replace some proken axle shims though, so whenever that happens, i'll try to remember to get a measurement.
    you want as big of a head on the bolt as you can get that will still fit in the hole of the spring perch, while still maintaining a bolt diameter that will fit through the springs.
  18. Oct 9, 2013 at 6:58 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    I believe I told you this a few months ago after your"drifting" accident. That you were not abke to move the rear diff because of the pin
    Also have to shave the head round so it would fit
  19. Oct 9, 2013 at 7:01 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i think i actually got a bolt with a head that just barely fit, creating a tighter center than a standard pin.
  20. Oct 9, 2013 at 7:03 AM
    Delmarva
    Tucson, AZ
    Was driving kiddo to school and saw a guy walking around the neighborhood.... Eating donuts... Was funny as hell
Thread Status:
