Houston Texas
Discussion in 'Performance and Tuning' started by czwhat, May 30, 2013.
  1. May 30, 2013 at 2:09 PM
    czwhat
    czwhat [OP] Member
    Anyone know of a shop in Houston that can dyno tune a Tacoma?
  2. May 30, 2013 at 4:46 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I know of a few. What EMS are you wanting to get tuned?
  3. May 30, 2013 at 7:34 PM
    keylay
    keylay Well-Known Member
    Kyle
    Houston
    03 4Runner 4WD
    Power Fab?
    Didn't they build a couple turbo X-Runners?
  4. May 31, 2013 at 5:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    PowerFab is definitely one of them, and yes as far as I know, the only company to have built multiple turbo kits for '05+ Tacomas.
    Kozmic is also quite capable. Right down 1960 from PowerFab. Near Mills Rd.
  5. May 31, 2013 at 1:33 PM
    czwhat
    czwhat [OP] Member
    I would love to run the Econ Ems but they still haven't released on for the 2010's. I was looking into maybe the unichip but am still not sure which to run.
  6. May 31, 2013 at 1:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you can find an authorized Unichip tuner, then you can make a decent change in power. It is a bottom of the line tuner though. Get the plug n play harness off of it then wire up an extension harnss to it to be used with the UCON, or AEM, or Haltech, or ProEFI.
